Option Base 1
'Author: Timothy R. Mayes, Ph.D.
'Website: http://www.tvmcalcs.com/blog/
'Version: 1.0
'Date: 2/5/2009
'This code creats a "live" variance/covariance matrix on your worksheet.
'It sets up a range with matrix functions linked to your data, so it will
'update automatically if the data changes.
'It can create either a normal var/cov matrix, or a probability weighted var/cov matrix.
'It can show the entire matrix, hide the upper part, or hide the lower part.
'It can create a population or sample var/cov matrix. Note that Excel only does population.
'Formulas (using fake named ranges)
'If Data are in columns:
'Equal Weighted: =MMULT(TRANSPOSE(Data - Mean), Data - Mean)/VarCount
'Unequal Weighted: =MMULT(TRANSPOSE(Weights*(Data - Mean)), Data - Mean)
'If Data are in rows:
'Equal Weighted: =MMULT(Data - Mean, TRANSPOSE(Data - Mean))/VarCount
'Unequal Weighted: =MMULT(Data - Mean, TRANSPOSE(Weights*(Data - Mean)))
'Note: Means are calculated within the formulas as a weighted (equal or unequal) average.
'This makes the actual formulas long and ugly, but don't need a separate range for averages.
'Planned Updates:
'None at this time
'Acknowledgements:
'Thanks to Dave Peterson for helping me to figure out a hack for the 255 character limit in .FormulaArray by using .Replace and a fake string
'His method was posted at http://www.dailydoseofexcel.com/archives/2005/01/10/entering-long-array-formulas-in-vba/
'The global ribbon object
Dim grxIRibbonUI As IRibbonUI
Sub rxIRibbonUI_onload(ribbon As IRibbonUI)
'Set up the ribbon variable so that we can add to it
Set grxIRibbonUI = ribbon
Sub rxbtn_CovMatrix(control As IRibbonControl)
'Callback for ExcelSim onAction
'Call the CovMatrix() sub to run the add-in code
Dim w As Workbook
Dim Cnt As Integer
Dim FName As Variant
Cnt = 0
'Count how many regular workbooks are open, not counting personal.xls*
For Each w In Application.Workbooks
FName = Split(w.Name, "."
If (w.IsAddin = False And StrComp(FName(0), "personal", vbTextCompare) <> 0) Then Cnt = Cnt + 1
'If 1 or more regular workbooks, then run the add-in. Otherwise give an error message and exit.
If Cnt > 0 Then
Call CovMatrix
MsgBox "You must have an open workbook to use this add-in", vbOKOnly, "Covariance Matrix Add-in"
Exit Sub
Sub CovMatrix()
Dim WeightRng As Range
Dim InputRng As Range
Dim LabelRng As Range
Dim OutputRng As Range
Dim TmpRng As Range
Dim LeftLabels As Range, TopLabels As Range
Dim HasTitle As Byte
Dim HidePartofMatrix As Byte
Dim MeanStr As String
Dim InputSht As String, OutputSht As String, WeightStr As String
Dim NumVars As Integer
Dim i As Integer
Dim LabelArray()
Dim c As Variant
Const FakeStr As String = "X_X_X" 'This is a place holder to make FormulaArray work with formulas > 255 characters, it will be replaced
CovDialog.Show
If CovDialog.CancelPressed Then
Unload CovDialog
Exit Sub
'Get the Data into our range variables
Set InputRng = Range(CovDialog.InputEditBox.Text)
Set OutputRng = Range(CovDialog.OutputEditBox.Text).Cells(1, 1) 'We only want upper-left corner, we will calculate the rest
If CovDialog.WeightsEditBox.Text <> "" Then
Set WeightRng = Range(CovDialog.WeightsEditBox.Text)
Set WeightRng = Nothing
If CovDialog.LabelsBox = True Then 'Set LabelRng and Resize InputRng to remove labels
If CovDialog.ColumnButton = True Then 'Labels in first row
Set LabelRng = Range(InputRng.Cells(1, 1), InputRng.Cells(1, InputRng.Columns.Count))
Set InputRng = Range(InputRng.Cells(2, 1), InputRng.Cells(InputRng.Rows.Count, InputRng.Columns.Count))
NumVars = InputRng.Columns.Count
Else 'Labels in first column
Set LabelRng = Range(InputRng.Cells(1, 1), InputRng.Cells(InputRng.Rows.Count, 1))
Set InputRng = Range(InputRng.Cells(1, 2), InputRng.Cells(InputRng.Rows.Count, InputRng.Columns.Count))
NumVars = InputRng.Rows.Count
'Labels not selected, so no LabelRng
Set LabelRng = Nothing
If CovDialog.ColumnButton = True Then NumVars = InputRng.Columns.Count Else NumVars = InputRng.Rows.Count
If CovDialog.TitleBox = True Then HasTitle = 1 Else HasTitle = 0 '1 if has a title, 0 otherwise
'Get Sheet Names for input data and output data. Note that we are grabbing the first cell in the zero-based array.
InputSht = Split(CovDialog.InputEditBox.Text, "!"
(0)
OutputSht = Split(CovDialog.OutputEditBox.Text, "!"
(0)
If Not WeightRng Is Nothing Then WeightStr = Split(CovDialog.WeightsEditBox.Text, "!"
(0)
'If sheet names are the same, set InputSht to InputRng.Address because we don't need the sheet name.
If StrComp(InputSht, OutputSht, vbTextCompare) = 0 Then
InputSht = InputRng.Address
If Not WeightRng Is Nothing Then WeightStr = WeightRng.Address
Else 'Sheet names are different, add sheet name to addresses if possible
If InStr(CovDialog.InputEditBox.Text, "!"
Then InputSht = InputSht + "!" + InputRng.Address Else InputSht = InputRng.Address
If InStr(CovDialog.WeightsEditBox.Text, "!"
Then WeightStr = WeightStr + "!" + WeightRng.Address Else WeightStr = WeightRng.Address
If CovDialog.AllButton = True Then
HidePartofMatrix = 0 'Show all of matrix
If CovDialog.LowerButton = True Then
HidePartofMatrix = 1 'Show only lower half of matrix
HidePartofMatrix = 2 'Show only upper half of matrix
'Build the string that calculates the mean to simplify the actual formula string
If CovDialog.ColumnButton = True Then 'Variables in Columns
If WeightRng Is Nothing Then
'Equal weighted
MeanStr = "MMULT(TRANSPOSE(N(ISNUMBER(ROW(" + InputSht + "
))/ROWS(" + InputSht + "
)," + InputSht + "
'Unequal weights
MeanStr = "MMULT(TRANSPOSE(" + WeightStr + "
," + InputSht + "
Else 'Variables in Rows
'Equal weighted
MeanStr = "MMULT(" + InputSht + ",TRANSPOSE(N(ISNUMBER(COLUMN(" + InputSht + "
))/COLUMNS(" + InputSht + "
'Unequal weights
MeanStr = "MMULT(" + InputSht + ",TRANSPOSE(" + WeightStr + "
'Calculate Output Range and write labels and formulas
ReDim LabelArray(1 To NumVars)
If LabelRng Is Nothing Then 'If labels aren't supplied, give defaults
For i = 1 To NumVars
LabelArray(i) = "Var " + VBA.Format(i, "#"
Else 'Otherwise, place the given labels into LabelArray
i = 0
For Each c In LabelRng
i = i + 1
LabelArray(i) = c.Text
'This section is where we create, format, and write the output
'If output area has data, then clear the range where we will write the results
Set TmpRng = Range(OutputRng.Offset(0, 0), OutputRng.Offset(NumVars + HasTitle, NumVars))
If Application.WorksheetFunction.CountBlank(TmpRng) = TmpRng.Count Then
TmpRng.Clear
i = MsgBox("The output range contains data. Click OK to overwrite.", vbOKCancel)
If i = 2 Then
Exit Sub 'Exit if user doesn't want to overwrite existing data
TmpRng.Clear
If Err.Number <> 0 Then 'Probably can't clear because there is overlap with an array formula
MsgBox "Cannot clear the output range. Try manually clearing it, or change output range. Exiting routine." + VBA.Chr(13) + VBA.Chr(13) + "Error: " + Err.Description, vbOKOnly
Exit Sub
Set LeftLabels = Range(OutputRng.Offset(1 + HasTitle, 0), OutputRng.Offset(NumVars + HasTitle, 0))
Set TopLabels = Range(OutputRng.Offset(0 + HasTitle, 1), OutputRng.Offset(0 + HasTitle, NumVars))
LeftLabels.Value = WorksheetFunction.Transpose(LabelArray) 'Write left column labels
TopLabels.Value = LabelArray 'Write top row labels
Set OutputRng = Range(OutputRng.Offset(1 + HasTitle, 1), OutputRng.Offset(NumVars + HasTitle, NumVars))
'Equal weighted covariance
If CovDialog.ColumnButton = True Then 'Variables in columns
If CovDialog.PopButton Then
OutputRng.FormulaArray = "=MMULT(TRANSPOSE(" + InputSht + "-" + FakeStr + "
,(" + InputSht + "-" + FakeStr + "
)/Rows(" + InputSht + "
)/(Rows(" + InputSht + "
-1)"
Else 'Variables in rows
OutputRng.FormulaArray = "=MMULT(" + InputSht + "-" + FakeStr + ",transpose(" + InputSht + "-" + FakeStr + "
)/Columns(" + InputSht + "
)/(Columns(" + InputSht + "
-1)"
'Not equal weighted covariance
OutputRng.FormulaArray = "=MMULT(TRANSPOSE(" + WeightStr + "*(" + InputSht + "-" + FakeStr + "
),(" + InputSht + "-" + FakeStr + "
OutputRng.FormulaArray = "=MMULT(" + InputSht + "-" + FakeStr + ",TRANSPOSE(" + WeightStr + "*(" + InputSht + "-" + FakeStr + "
OutputRng.Replace FakeStr, MeanStr 'This replaces the FakeStr that we put in to shorten the formula so that FormulaArray would work
'Format the output
With LeftLabels
.Font.FontStyle = "Bold Italic"
.HorizontalAlignment = xlRight
With TopLabels
.Borders(xlEdgeTop).Weight = xlMedium
.Borders(xlEdgeBottom).Weight = xlThin
.HorizontalAlignment = xlCenter
With TopLabels.Offset(0, -1)
If HasTitle = 1 Then 'Add a title, if requested
TopLabels.Offset(-1, -1).Cells(1, 1).Value = "Population Variance/Covariance Matrix"
TopLabels.Offset(-1, -1).Cells(1, 1).Value = "Sample Variance/Covariance Matrix"
TopLabels.Offset(-1, -1).Cells(1, 1).Value = "Weighted Variance/Covariance Matrix"
With Range(TopLabels.Offset(-1, -1), TopLabels.Offset(-1, 0))
.HorizontalAlignment = xlHAlignCenterAcrossSelection
With OutputRng 'Format the numbers and add a border at bottom
.NumberFormat = "0.00000_)"
.Borders(xlEdgeBottom).Weight = xlMedium
OutputRng.Offset(0, -1).Borders(xlEdgeBottom).Weight = xlMedium
If HidePartofMatrix = 1 Then 'Hide upper half of matrix
For i = 1 To NumVars - 1
With Range(OutputRng.Cells(i, 1 + i), OutputRng.Cells(i, NumVars))
.Font.Color = .Interior.Color
If HidePartofMatrix = 2 Then 'Hide lower half of matrix
For i = 2 To NumVars
With Range(OutputRng.Cells(i, 1), OutputRng.Cells(i, i - 1))
Unload CovDialog
