How to avoid #N/A in results when using vlookup
Abhinandan
Dear All,
How can I avoid having #N/A as result when using vlookup.
A blank or Zero in result would be ok .
Regards,Abhi
hi abhinandan,
use 'iferror' with vlookup to avoid #N/A
=iferror(VLOOKUP(lookup_value, table_array, col_index_num, [range_lookup]),0))
If you have Excel 2013+ and want to specifically target #N/A errors then you can use the IFNA() function.
=IFNA(VLOOKUP(Lookup_Value,Table_array,Col_index_num,Range_lookup),"")
If you have Excel 2007+ and want to target all errors you can use IFERROR().
=IFERROR(VLOOKUP(Lookup_Value,Table_array,Col_index_num,Range_lookup),"")
If you have earlier versions then you have to use a combination of IF() and either ISNA() or ISERROR().
=IF(ISERROR(VLOOKUP(Lookup_Value,Table_array,Col_index_num,Range_lookup)),"",VLOOKUP(Lookup_Value,Table_array,Col_index_num,Range_lookup))
The IFNA() option is also available in 2010.
You must have a special version of Excel 2010! :)
I don't have Excel 2010/3 available to hand to double check this, but I think it was introduced only in 2013. It was one of the new 2013 worksheet functions I listed here.
