Ankur Kumar
Hi All,
Here is my code , while i am sending particular one sheet from workbook i am unable to see the body message and signature as in outlook, please help me out how can i add this.
Sub Mail_ActiveSheet()
'Working in Excel 2000-2016
'For Tips see: http://www.rondebruin.nl/win/winmail/Outlook/tips.htm
Dim FileExtStr As String
Dim FileFormatNum As Long
Dim Sourcewb As Workbook
Dim Destwb As Workbook
Dim TempFilePath As String
Dim TempFileName As String
Dim OutApp As Object
Dim OutMail As Object
With Application
.ScreenUpdating = False
.EnableEvents = False
Set Sourcewb = ActiveWorkbook
'Copy the ActiveSheet to a new workbook
Sheet2.Copy
Set Destwb = ActiveWorkbook
'Determine the Excel version and file extension/format
With Destwb
If Val(Application.Version) < 12 Then
'You use Excel 97-2003
FileExtStr = ".xls": FileFormatNum = -4143
'You use Excel 2007-2016
Select Case Sourcewb.FileFormat
Case 51: FileExtStr = ".xlsx": FileFormatNum = 51
Case 52:
If .HasVBProject Then
FileExtStr = ".xlsm": FileFormatNum = 52
Case 56: FileExtStr = ".xls": FileFormatNum = 56
Case Else: FileExtStr = ".xlsb": FileFormatNum = 50
End Select
' 'Change all cells in the worksheet to values if you want
' With Destwb.Sheets(1).UsedRange
' .Cells.Copy
' .Cells.PasteSpecial xlPasteValues
' .Cells(1).Select
' End With
' Application.CutCopyMode = False
'Save the new workbook/Mail it/Delete it
TempFilePath = Environ$("temp") & "\"
TempFileName = "Invoice Listing" & " " & Format(Now, "dd-mmm-yy h-mm-ss")
strbody = "Dear Team," & vbNewLine & vbNewLine & _
"Please find attached today's invoice listing"
With Destwb
.SaveAs TempFilePath & TempFileName & FileExtStr, FileFormat:=FileFormatNum
With OutMail
.Display
.To = "prasoon.p@vccircle.com;ekta.khanna@vccircle.com"
.CC = "virender.manral@vccircle.com;shalil.gupta@vccircle.com;accounts@vccircle.com"
.BCC = ""
.Subject = "Invoice Listing" & " " & Format(Date, "dd/MM/yyyy")
.Body = strbody & vbNewLine & .Body
.Attachments.Add Destwb.FullName
'You can add other files also like this
'.Attachments.Add ("C:\test.txt")
.Send 'or use .Display
On Error GoTo 0
.Close savechanges:=False
'Delete the file you have send
Kill TempFilePath & TempFileName & FileExtStr
Set OutMail = Nothing
Set OutApp = Nothing
With Application
.ScreenUpdating = True
.EnableEvents = True
