How to abruptly stop a running VBA code
Raja Kamarthi
Team,
Is there a way to stop a running VBA code?
Have a code which loops based on a condition and the condition has gone wrong and inturn executing the code to run for ever.
Any quick thoughts?
Raja
Hi Raja ,
The standard way to interrupt execution of a program is CTRL BREAK.
However , that is a minor point ; a more important point is :
never use an equal to condition to stop a loop ; always use >= or <= , depending on which is applicable ; a check for equality may not result in a TRUE value depending on several factors , some of which do not have to do with logic , but with the way the computer does calculations and / or stores numbers.
Checking for >= or <= is always preferable to checking strictly for equality , unless you can ensure that the result will always happen , at some stage.
Of course , in your case , the problem is that you are not incrementing the loop variable. Instead of :
[pre]
[A1] = i + 1
use
i = i + 1
[A1] = i
[/pre]
Many Thanks, Deb
I tried stopping the code but failed and suddenly all my open excel files got closed.
My hardwork put on a report had gone waste since I didnt save.
Need to start again from scratch :(
Raja
HI
Of course you can program in an "exit" with error trapping:
Sub KeepDoingSomething()
Application.EnableCancelKey = xlErrorHandler
On Error GoTo ErrHandler
Dim i As Integer
i = 0
Do Until i = 10
[A1] = i + 1
Debug.Print i
Loop
Application.EnableCancelKey = xlInterrupt
Exit Sub
ErrHandler:
If Err.Number = 18 Then
lContinue = MsgBox(prompt:=Format(x / y, "0.0%") & _
" complete" & vbCrLf & _
"Do you want to Continue (YES)?" & vbCrLf & _
"Do you want to QUIT? [Click NO]", _
Buttons:=vbYesNo)
If lContinue = vbYes Then
Resume
MsgBox ("Program ended at your request")
Exit Sub
Which monitors Esc or Ctrl+Break during the running of your code.
G
Hi, Raja Kamarthi!
A good practice to avoid unwanted eternal loops when developing VBA code is to use the DoEvents statement within the loop, so as to enable single Ctrl-Break key pressings to be handled by Excel and make it enters in debugging mode.
Despite the right correction made by NARAYANK991, in your original code (if in the corrected it wouldn't have sense), try this:
[pre]
Dim i As Integer
i = 0
Do Until i = 10
[A1] = i + 1
Debug.Print i
DoEvents
Loop
[/pre]
And then run it and press Ctrl-Break, it should stop and enter in debugging mode instantly.
Regards!
