How can I copy and paste using an Array formulas within my Macro
Presently I am using a Macro that will copy / paste or copy and insert to move the data from the Drawn Number sheet to the Input sheet. The problem I am running in to is when it inserts the new numbers in columns I to N the Array formulas in columns B to G do not change nor move down correctly to "match" the data in I to N. Is there a different method I can use (other than an Array) or a way to change up my Macro to accommodate this so it works properly?
Here is the file with Macros
https://www.mediafire.com/?h5fnq0fh02s3u04
Here are the Macros
Sub NumbersGrabber()
  Dim InputSht As Worksheet
  Dim DrnNumSht As Worksheet
  Dim i, r As Long
  Dim LastRowFound As Boolean
  Set InputSht = Sheets("Input")
  Set DrnNumSht = Sheets("Drawn Number ")
  LastRowFound = False
  r = 1
  Do
  r = r + 1
  If Not WorksheetFunction.IsNumber(DrnNumSht.Cells(r, "I")) Then
  LastRowFound = True
  r = r - 1
  Loop Until LastRowFound
  For i = r To 2 Step -1
  DrnNumSht.Cells(i, "I").Resize(, 7).Copy
  InputSht.Range("I49").Resize(, 7).Insert shift:=xlShiftDown
  ertert
