How can I activate each item and parse their info?
shahin
Hi there! Hope you all are doing fine. Today i came across a different type of problem while scraping a webpage. So far, when there is a button to click to get to the target page, I scraped the href of that button and parsed the data of that page by reaching there making another request. However, in this case I found some img's instead of href's connected to each button. When I scraped those img's, I got genuine image links in lieu of any fruitful links that can lead me to the target area. The page I'm dealing with contains several images. When an image is clicked, new information concerning its' flavor comes up under the image. My goal is to parse all the flavors connected to each image. My script can parse the flavors of currently active image. How can I select other images and parse their flavor as well? Thanks in advance.
Sub Web_Data()
    Dim http As New XMLHTTP60, html As New HTMLDocument
    Dim post As HTMLHtmlElement, elem As Object
    With http
        .Open "GET", "https://www.optigura.com/uk/product/gold-standard-100-whey/", False
        .send
        html.body.innerHTML = .responseText
    For Each post In html.getElementsByClassName("colright")
        With post.getElementsByClassName("opt2")(0).getElementsByTagName("label")
            For N = 0 To .Length - 1
                x = x + 1: Cells(x, 1) = .item(N).innerText
            Next N
    Next post
'Here i parsed the button links connected to each image but found the image itself instead of any href
'    For Each elem In html.getElementsByClassName("img")
'        With elem.getElementsByTagName("img")
'        If .Length Then x = x + 1: Cells(x, 1) = .item(0).src
'        End With
'    Next elem
The picture underneath can give you the clarity if anything I failed to describe.
I tried with Post request but got nothing. Perhaps I'm doing something wrong in making proper requests:
Sub httpPost()
    Dim argumentString As String
    argumentString = "opt=flavor&opt1=207&opt2=47&ip=105"
    With http
        .Open "POST", "https://www.optigura.com/product/ajax/details.php", False
        .setRequestHeader "User-Agent", "Mozilla/5.0 (Windows NT 6.1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36"
        .setRequestHeader "Content-type", "application/x-www-form-urlencoded"
        .setRequestHeader "Accept", "application/json, text/javascript, */*; q=0.01"
        .send argumentString
    MsgBox http.responseText
Finally, I've made it. To receive the required response it is necessary to send a GET request first then again send a POST request using the response from that get request. Here is the working one:
Sub httpPost()
    Dim ArgumentStr As String
    ArgumentStr = "opt=flavor&opt1=207&opt2=47&ip=105"
    With http
        .send
    With http
        .setRequestHeader "X-Requested-With", "XMLHttpRequest"
        .send ArgumentStr
