HLOOKUP Function problem [SOLVED]
paulpap
Hi all,
I am trying to use to HLOOKUP function on the following example:
In row 1 I have text
In row 2 I have numbers
C1 C2 C3 C4
10 20 30 40
In A4 I give the number 30
How can I use HLOOKUP to return the C3 in A5?
HLOOKUP(A4;A1:D2;1;FALSE) does not work (gives me a #N/A)
Can you please help me?
Thanks a lot
Hi Paul ,
The HLOOKUP function needs to find the lookup value in the first row of the range.
In your case , you say that the first row , row 1 , has text ; clearly , the value 30 is not to be found in the first row. Hence your HLOOKUP will return #N/A.
Since the numbers are in the second row , using HLOOKUP will make your formula complex ; it is easier to use INDEX + MATCH as follows :
=INDEX(A1:D1;MATCH(A4;A2:D2;0))
If you really want to use the HLOOKUP function , try this :
=HLOOKUP(A4,CHOOSE({2;1},A1:D1,A2:D2),2,FALSE)
Hi Narayan,
Thanks for your immediate answer.
Of course I preferred the 1st formula and it worked fine.
Paul
