High and low values in Excel charts
Hi all,
i am trying to highlight high and low values in a chart as the title says.
I do not know excel but by searching around i found two ways to accomplish this but i have not managed one of them to work.
Both ways suggest to create two more columns (one for min and one for max values) and add the below formulas.
(Below i write only for high values ,min values are similar)
Way 1
(for high value) uses a formula like this :
=IF(B2=MAX(Value),B2,0)
(for low value) uses a formula like this :
=IF(B2=MIN(Value),B2,0)
Way 2
=IF($B2=MAX($B$2:$B$14),$B2,NA())
=IF($B2=MIN($B$2:$B$14),$B2,NA())
When i try either way i get a "the formula you typed contains an error" message
So after many tries i didn't manage any of the two ways to work.
Is it because they refer to another excel version than mine? I have 2007 while it is not clear in which excel version they refer.
Probably i am doing something wrong.
I attach the excel in case some good man could help me out.
Thank you for your time reading this and excuse my lame English.
the_observer.
  • question.xlsx
There is nothing wrong with your formulae ; probably your Excel version uses the semi-colon ; as a separator instead of the comma.
Thank you much Narayank.
The second way works like a charm.
Thank you mate.
The first way though returns a #NAME? in the cell.
I will continue with the 2nd way i guess.
Thank you again.
the_observer.
The error is because Value is actually to be created ; it is a named range.
Go to the Name Manager , and create a named range called Value , and in the Refers To box , enter =$B$2:$B$14
Now , the formula will work.
