Please check the below code I need to change reading source from Sheets("Data")
to external workbook located in C:Data.xlsx
Also this MsgBox "Search item not found" always showing to me even data copied well.
Sub test1()
'Search
Dim Search As String
Dim i As String
On Error GoTo ErrorCatch
Search = Range("A1").Value
Sheets("Data").Select
Columns("A:E").Select
Selection.Find(What:=Search, After:=ActiveCell, LookIn:=xlFormulas, _
LookAt:=xlWhole, SearchOrder:=xlByRows, SearchDirection:=xlNext, _
MatchCase:=False, SearchFormat:=False).Select
'Copy record to Entry
ActiveCell.Offset(0, 1).Range("A1:E1").Select
i = 1
Sheets("Entry").Select
Range("D4").Select
Do
If ActiveCell <> "" Then
Selection.Copy
:=False, Transpose:=True
ActiveCell.Offset(2, 0).Select
Sheets("Database").Select
i = i + 1
ActiveCell.Offset(0, 1).Select
Loop Until i = 5
'Move to second column
Range("E4").Select
i = 1
Do
Selection.Copy
i = i + 1
Loop Until i = 5
'Delete old record
Selection.ClearContents
Exit Sub
ErrorCatch:
Sub test1()
'Search
Dim i As String
i = 1
Range("D4").Select
Do
Selection.Copy
i = i + 1
Loop Until i = 5
Range("E4").Select
i = 1
Do
Selection.Copy
i = i + 1
Loop Until i = 5
'Delete old record
Exit Sub
ErrorCatch:
