HELP with SUMIFS
I know that there is an error and it's no the right way to do it, but how do I incorporate the text value function into my SUMIFS formula? I need to get a sum of the numbers if the first 2 characters of a cost center are numeric vs letters. Here is what I got so far (I know it's not right - need help with the right-most function):
=SUMIFS('Data Tab'!C:C,'Data Tab'!A:A,$A2,'Data Tab'!B:B,ISNUMBER(VALUE(LEFT('Data Tab'!B:B,2))))
Please help with the red part of the formula. I am getting a #SPILL! error.
Thank you!
If you have 365:
=SUM(FILTER('Data Tab'!C.:.C,('Data Tab'!A.:.A=$A2)*(ISNUMBER(-(LEFT('Data Tab'!B.:.B,2))))))
SUMIFS is not really going to work for what you are doing.
A2 is blank in that file, so there are no matching results. You should have used A1 as the criterion cell.
To handle no matches:
=SUM(FILTER('Data Tab'!C.:.C,('Data Tab'!A.:.A=$A2)*(ISNUMBER(-LEFT('Data Tab'!B.:.B,2))),0))
Thank you, but it still didn't work - the error now is #VALUE.
I haven't used the FILTER function in a while, but why did you put the minus sign before LEFT?
Thanks again!
LEFT always returns text, so applying the unary - operator will either convert it to a number or return an error and pass the result to ISNUMBER to return TRUE or FALSE accordingly.
The formula works in your sample file. Are there any errors in your real data file?
