Help with sorting parts
Davealot
Greetings,
I apologize for asking another question to the forum, but I am very appreciative of all of the help I've received thus far. I'm in need of sorting a set of parts out, I've wrote code that is done incorrectly and I can't figure out what's wrong, specifically I am not sure how to have it offset on sheet 2 when a value is posted, I would like for the code to inspect each cell in Column A until it is empty, and if the first 5 numbers are <= 76249 to place on Sheet 2 starting in column A and if it is >= 76250 then to paste them on sheet 2 starting in column G. I've attached spreadsheet as well as Code that I wrote that fails like a champ. Any help would be greatly appreciate, and again thank you.
Sheets.Add After:=ActiveSheet
    Sheets("Sheet1").Select
    Range("A2").Select
Do Until IsEmpty(ActiveCell)
    If Left(ActiveCell, 5) <= "76249" Then
    Range("A2:E2").Select
    Selection.Copy
    Sheets("Sheet2").Select
    ActiveSheet.Paste
    Range("A:E").Select
        Selection.Delete Shift:=xlUp
        Range("A:E").Select
        Loop
I'f you'll notice I haven't even bothered with the ">=76250" as I can't even get the first part to work. Thank you.
  • Book1.xlsx
Hi !
This is limit to a duplicate post !
If you go this way, the execution will last much more
than the way I gave you in your previous post …
This would be how I'd do it.
Sub Test()
Dim origWs As Worksheet, destWs As Worksheet
Dim lRow As Long
Dim cel As Range
Set origWs = ThisWorkbook.Worksheets("Sheet1")
Set destWs = ThisWorkbook.Worksheets("Sheet2")
With origWs
    If .AutoFilterMode = True Then .AutoFilterMode = False
    .Cells(1, 6) = "TempCol"
    lRow = .Cells(Rows.Count, 1).End(xlUp).Row
    For Each cel In .Range("A2:A" & lRow)
        cel.Offset(0, 5) = Left(cel.Value, 5)
    Next cel
    .Cells.CurrentRegion.AutoFilter Field:=6, Criteria1:="<=76249", Operator:=xlFilterValues
    .Range("A1:E" & lRow).SpecialCells(xlCellTypeVisible).Copy destWs.Cells(1, 1)
    .Cells.CurrentRegion.AutoFilter Field:=6, Criteria1:=">=76250", Operator:=xlFilterValues
    .Range("A1:E" & lRow).SpecialCells(xlCellTypeVisible).Copy destWs.Cells(1, 7)
    .Range("F:F").Delete
Hi !
My apologies, I am not attempting to duplicate posts, and I understand how it could be seen that way, my apologies
Sub Test()
Dim lRow As Long
Dim cel As Range
With origWs
    Next cel
This works great, thank you so very much!
