Ketan Mehta
Hi
Grateful for assistance regarding the below.
The code below works which saves and emails the active excel worksheet when a button is pressed on the excel sheet, what I would like to do is to add a message box in the code below which tells the user that the form has been submitted when this button has been pressed. Any ideas?
I did try to add a code for a message box but it is being created as a seperate sub routine and message does not appear. Just need a simple message that says "Your form has been submitted, thank you"
<<< use code -tags >>>
Sub Mail_ActiveSheet()
Dim FileExtStr As String
Dim FileFormatNum As Long
Dim Sourcewb As Workbook
Dim Destwb As Workbook
Dim TempFilePath As String
Dim TempFileName As String
Dim OutApp As Object
Dim OutMail As Object
With Application
.ScreenUpdating = False
.EnableEvents = False
Set Sourcewb = ActiveWorkbook
'Copy the ActiveSheet to a new workbook
ActiveSheet.Copy
Set Destwb = ActiveWorkbook
'Determine the Excel version and file extension/format
With Destwb
If Val(Application.Version) < 12 Then
'You use Excel 97-2003
FileExtStr = ".xls": FileFormatNum = -4143
'You use Excel 2007-2016
Select Case Sourcewb.FileFormat
Case 51: FileExtStr = ".xlsx": FileFormatNum = 51
Case 52:
If .HasVBProject Then
FileExtStr = ".xlsm": FileFormatNum = 52
Case 56: FileExtStr = ".xls": FileFormatNum = 56
Case Else: FileExtStr = ".xlsb": FileFormatNum = 50
End Select
' 'Change all cells in the worksheet to values if you want
' With Destwb.Sheets(1).UsedRange
' .Cells.Copy
' .Cells.PasteSpecial xlPasteValues
' .Cells(1).Select
' End With
' Application.CutCopyMode = False
'Save the new workbook/Mail it/Delete it
TempFilePath = Environ$("temp") & "\"
TempFileName = "Part of " & Sourcewb.Name & " " & Format(Now, "dd-mmm-yy h-mm-ss")
With Destwb
.SaveAs TempFilePath & TempFileName & FileExtStr, FileFormat:=FileFormatNum
With OutMail
.to = ""
.CC = ""
.BCC = ""
.Subject = "Order Form"
.Body = "Hi there"
.Attachments.Add Destwb.FullName
'You can add other files also like this
'.Attachments.Add ("C:\test.txt")
.Send 'or use .Display
On Error GoTo 0
.Close savechanges:=False
'Delete the file you have send
Kill TempFilePath & TempFileName & FileExtStr
Set OutMail = Nothing
Set OutApp = Nothing
With Application
.ScreenUpdating = True
.EnableEvents = True
