Hi All,
I have a very weird request for a code.
I have a sheet which query the web for result. I input a value in cell G2, the web query runs as its on a refresh based on cell value. There are results that are populated in Range H2:N3.
I currently have to manual input the ID, then copy the values in Range G2:N3 and paste it in next sheet.
i would like to ask help of the members for a code, where i can input the ID in Col A of the sheet and run the macro to get a consolidated result.
The web refresh takes about 3-5 sec for some ID otherwise it is about 1-2 sec.
I have also uploaded the file. minus the web query.
TO summarize, it should copy the value from Col A and paste in G2 and copy G2:N3 and do a paste special values & formatting in the next sheet and repeat the process until it finds a blank cell in Col A.
Sudi
Sudi
