Help with Index and Match formula
gmfston
Hello Ninjas,
I need help with a formula that will populate values from the Balance Sheet tab to the Trial Balance tab referencing the general ledger account numbers. The issue is that the account numbers in the balance sheet tab vary in length, are listed in different columns, and the accounts highlighted in yellow need to be populated in the trial balance tab as negative numbers so that the trial balance nets to zero. Thank you in advance for your help. Best, Gina
  • Chandoo 01.10.18.xlsx
Hello Ninjas,
Attached is the file where I as able to insert the formula to populate the correct amounts from the balance sheet tab to the trial balance tab. I just need to add a condition that converts the amounts highlighted in yellow (liabilities and equity) on the balance sheet tab to the trial balance (1st) tab as a negative amount or credit. The attachment illustrates my expected results. Any help to add this condition to the attached formula is greatly appreciated!
In D10, copied down :
=IFERROR(OFFSET('Balance Sheet'!$G$4,AGGREGATE(14,6,ROW('Balance Sheet'!$C$1:$C$90)/ISNUMBER(SEARCH("#"&B10&" · ","#"&'Balance Sheet'!$C$5:$F$94)),1),)*IF(LEFT(B10)>"1",-1,1),"")
Bosco
