Help with Formula to arrange words order in cell.
Hello, I am trying to find out the way to arrange the word order in a cell in excel. I managed to get some word changing with a formula, but it still does not do what I need. As you can see, in cell A1, there is a name "Sonnervig,Luiza,Ms.".
I got this formula: =IFERROR(TRIM(RIGHT(A1,LEN(A1)-SEARCH(",",A1))&" "&LEFT(A1,SEARCH(",",A1)-1)),"").
The result of the formula is "Luiza,Ms. Sonnervig".
The result that I need is "Ms. Luiza Sonnervig".
I have tried different ways but for some reason, I can´t fathom, the result is so far away from my little knowledge!
Is there a way in order to get what I want?
I am attaching the file I am using.
Once again, thank you so much in advance.
  • Reorder Names.xlsm
If you have access to TEXTJOIN and FILTERXML functions as well as if your data is as consistent as in the sample then you can try below formula.
=TEXTJOIN(" ",TRUE,FILTERXML("<t><d>"&SUBSTITUTE(A1,",","</d><d>")&"</d></t>","//d["&{3,2,1}&"]"))
With Power Query, a case of simply splitting data on delimiter "comma" and then concatenating with a space.
let
    #"Split Column by Delimiter" = Table.SplitColumn(Source, "Column1", Splitter.SplitTextByDelimiter(",", QuoteStyle.Csv), {"Column1.1", "Column1.2", "Column1.3"}),
    #"Changed Type" = Table.TransformColumnTypes(#"Split Column by Delimiter",{{"Column1.1", type text}, {"Column1.2", type text}, {"Column1.3", type text}}),
    #"Merged Columns" = Table.CombineColumns(#"Changed Type",{"Column1.3", "Column1.2", "Column1.1"},Combiner.CombineTextByDelimiter(" ", QuoteStyle.None),"Merged")
in
    #"Merged Columns"
MMMM I tried and unfortunately I do not have access to TEXTJOIN and FILTERXML functions
In that case you can use:
=TRIM(MID(SUBSTITUTE(","&A1,",",REPT(" ",99)),3*99,99))&" "&TRIM(MID(SUBSTITUTE(","&A1,",",REPT(" ",99)),2*99,99))&" "&TRIM(MID(SUBSTITUTE(","&A1,",",REPT(" ",99)),1*99,99))
It looks longer but it is just the same formula i.e. TRIM(MID(SUBSTITUTE(","&A1,",",REPT(" ",99)),3*99,99)) written 3 times where red marked number is changed as per position requirement and concatenated with spaces.
This one worked amazing. Thank you so much.
And I modified it a little like this:
=IFERROR(TRIM(MID(A1,FIND(",",A1,FIND(",",A1)+1)+1,9)&MID(SUBSTITUTE(A1,",",REPT(" ",99)),99,99)&LEFT(A1,FIND(",",A1)-1)),"")
THANK YOU SO MUCH.
