Help with Error Expected Sub, Function or Property
Hi All,
I am trying unmerge, delete filter and copy the data to another workbook. however I get this error. Please advice.
Sub rawdata()
Dim lngStart As Long, lngEnd As Long
Dim lrow As Integer
    Sheet2.Activate
    Columns("A:F").Select
    Selection.UnMerge
    Range("C:C,F:F").Select
    Selection.Delete Shift:=xlToLeft
    Columns("E:E").Select
    Selection.NumberFormat = "[$-10409]m/d/yyyy"
  Sheet1.Activate
  lngStart = Range("C7").Value 'assume this is the start date
  lngEnd = Range("E7").Value 'assume this is the end date
  Sheet2.Activate
  Range("E:E").AutoFilter Field:=1, Criteria1:=">=" & lngStart, Operator:=xlAnd, Criteria2:="<=" & lngEnd
lrow = 2
  With Sheet2.Cells(2, 1).CurrentRegion
  .Offset(1).Resize(.Rows.Count).Copy
  Workbooks("Data File.xls").Activate
  ThisWorkbook.Sheets(1).Cells(lrow, 2).PasteSpecial xlPasteValues
  Application.CutCopyMode = False: lrow .Rows.Count - 1
You didn't say which line was causing the problem, but I'm guessing it's this one near the end:
Looks like you're missing a "=" between lRow and the .Rows.Count
  Application.CutCopyMode = False: lrow = .Rows.Count - 1
On a side note, I'm not sure why you are changing value of lRow right before the end of the sub anyway...
@Luke I made some changes and now I get another error message
Private Sub rawdata()
Dim lrow As Integer, ws As Workbook, ws1 As Workbook
Set ws = Workbooks("Book1.xlsm")
Set ws1 = Workbooks("Book2.xlsb")
    Sheet2.Activate
    Selection.UnMerge
  Sheet1.Activate
  Sheet2.Activate
'lrow = 2
  With Sheet2.Cells(1, 1).CurrentRegion
  ws1.Activate
  ThisWorkbook.Sheets(1).Cells(lrow, 1).PasteSpecial xlPasteValues
  Application.CutCopyMode = False: lrow = lrow + .Rows.Count - 1
ws1.Save
ws.Activate
ws.Close 0
