Help with Chandoo's instructions
niravrph
Hi there,
Been following the step-by-step instructions on Chandoo's link/tutorial:
http://chandoo.org/wp/2009/03/12/comparison-charts-1/
- and it says to put in some Index formulas. Trouble is, it doesn't say where I'm supposed to put it. I'm a novice. Can someone talk to me like I'm a 5 year old? I am stuck right there!
Thanks,
NIRAV
You would use them in the "Data Shown" table. The INDEX formulas will be used to return a specific portion of your data, based off the Index number (created by using the scroll bar). Chandoo then goes on to show how to modify the formula to get competitor #2 and #3.
