Help with a Data Entry form
DMA
Hi all and thanks in advance.
I'm trying to create a form, where, multiple users will need to enter in 3-4 data fields, similar to the chart seen here http://www.contextures.com/xlForm02.html#code
The data entered will be:
Name of place
Sub Name
Type of Record (can be drop-down of 3 choices)
Initials of Person Entering Data
The list of Name of Place/Sub-Name is rather large and the goal of creating this chart is to have users enter their data, and for excel to count how many are for each Place/Sub-Name of each specific Type of Record.
Is there a way to do this? Apologies if I'm unclear and thanks again.
cdbauer1
Is question: "How do I count the permutations?" or is it "How do I create a form that accomplishes this?"
DMA
Thanks for your response and apologies for my ignorance, but I think my question is both.
I need a form that accomplishes the ability to have multiple users enter their data (Name/SubName/Type) into one sheet field, that is then sent to an output sheet that places it in the corresponding/appropriate Name/SubName row with Type as column and tallies it for each.
i hope this makes sense!
DMA
If it helps, as an example, the user would see this page
Name:
SubName:
Type of Record:
and would enter as a possibility
SubName: XYZ
Type of Record: No Record
then this entry would fill in another sheet:
Name SubName No Record Record Other
ABC XYZ 1 0 0
DEF UVW 0 0 0
GHI RST 0 0 0
and would continue to tally as results came in
cdbauer1
@DMA I know there has to be a more elegant way than what I've written below but try it out - it worked in the file I attached.
Sub UpdateLogWorksheet()
'http://www.contextures.com/xlForm02.html
'code by Dave Peterson and modified by cdbauer1
'Make sure that your column headers on the PartsData tab go in the order of the Data Validation list and that they are identically named
    Dim historyWks As Worksheet
    Dim inputWks As Worksheet
    Dim nextRow As Long
    Dim oCol As Long
    Dim myRng As Range
    Dim myCopy As String
    Dim myCell As Range
    'cells to copy from Input sheet - some contain formulas
    myCopy = "C2,C3,C4"
    Set inputWks = Worksheets("Input")
    Set historyWks = Worksheets("PartsData")
    With historyWks
        nextRow = .Cells(.Rows.Count, "A").End(xlUp).Offset(1, 0).Row
    With inputWks
        Set myRng = .Range(myCopy)
        If Application.CountA(myRng) <> myRng.Cells.Count Then
            MsgBox "Please fill in all the cells!"
            Exit Sub
    With historyWks
        With .Cells(nextRow, "A")
            .Value = Now
            .NumberFormat = "mm/dd/yyyy hh:mm:ss"
        .Cells(nextRow, "B").Value = Application.UserName
        oCol = 3
        For Each myCell In myRng.Cells
            historyWks.Cells(nextRow, oCol).Value = myCell.Value
            If myCell.Value = "Record 1" Then
                historyWks.Cells(nextRow, oCol + 1).Value = 1
                historyWks.Cells(nextRow, oCol + 2).Value = 0
                historyWks.Cells(nextRow, oCol + 3).Value = 0
            If myCell.Value = "Record 2" Then
                historyWks.Cells(nextRow, oCol + 1).Value = 0
                historyWks.Cells(nextRow, oCol + 2).Value = 1
            If myCell.Value = "Record 3" Then
                historyWks.Cells(nextRow, oCol + 3).Value = 1
            oCol = oCol + 1
        Next myCell
    'clear input cells that contain constants
    With inputWks
         With .Range(myCopy).Cells.SpecialCells(xlCellTypeConstants)
              .ClearContents
              Application.Goto .Cells(1) ', Scroll:=True
      On Error GoTo 0
DMA
cdbauer1 I cannot thank you enough!
This is perfect. I edited the fields I needed and it works amazing!
I hope I can repay the favor.
Thanks again!
    Dim nextRow As Long
    Dim oCol As Long
    Dim myRng As Range
    Dim myCell As Range
    myCopy = "C2,C3,C4"
    With historyWks
    With inputWks
            Exit Sub
    With historyWks
            .Value = Now
        oCol = 3
            oCol = oCol + 1
        Next myCell
    With inputWks
              .ClearContents
      On Error GoTo 0
DMA
This is the excel I was referring to in my other thread.
Does anyone know how to add a quantity capacity to this?
Debraj
Hi DMA!
Please help us, to help you..
I tracked your all post.. and doesn't found any excel file..
Is it possible to upload a sample file expected output..
DMA
Hi Debraj,
I attached the file, I basically want that quantity line to be an input line which will then correspond to the corresponding type in the "partsdata" tab.
Thanks!
sgmpatnaik
@DMA
Try The Below Code
  Dim nextRow As Long
  Dim oCol As Long
  Dim myRng As Range
  Dim myCell As Range
  myCopy = "C2,C3,C4,C5"
  With historyWks
  With inputWks
  Exit Sub
  With historyWks
  .Value = Now
  oCol = 3
  If myCell.Value <> "" Then
  'historyWks.Cells(nextRow, oCol + 4).Value = 1
  oCol = oCol + 1
  Next myCell
  With inputWks
  .ClearContents
  Application.GoTo .Cells(1) ', Scroll:=True
  On Error GoTo 0
A Sample is attached
