help to create macro for combined report
mohan08
Hi All,
Can you help me with combined report with two input file.
Wanted to create macro to extract input file 1 and input file 2 to have one combined report comparing value against each store
  • Input 1 – We have 5 column
  • Input 2 – We need to add 2 helper column to have the same format month as input1
  • Output – to import input 1 data and match and update input 2 data by comparing date and child store
Hi !​
  • Considering to allocate output workbook without any formula via a VBA procedure
    so Input2 workbook does not need any helper column (if ok Input2 columns A & B - at least B - could be deleted) …
  • output workbook : Column L is superfluous as column K already does exactly the same : TRUE if result is 0 …
    Column H is superfluous too as column G … So if ok columns L & H must be deleted.
Despite the many result errors in output workbook, if you agree with both points, I'll post later a procedure.​
If not, don't worry as it's almost at beginner level, wait for another helper …​
Hi Marc,
so Input2 workbook does not need any helper column (if ok Input2 columns A & B - at least B - could be deleted) --> added helper column for input2 as I get raw data which will start from column C to G,
for second point its ok, to be deleted.
Can you help me with the code for the above.
I do not well 'catch' for Input2 workbook so the easy way is to attach the last version if different than the initial attachment​
or just confirm it stays like in the initial attachment, thanks.​
If you receive this workbook like that, just tell us but I just wanna say if your original workbook has no helper column​
a VBA procedure does not need you create any before …​
Column A maybe usefull if the year is not the current year or in case of multiple year like 2018M12 & 2019M01 for example.​
But column B is useless if you create it manually before executing the code.​
Here attached the raw file with no helper column A and B.
regarding the multiple year, the extract will be for last 3 months and it will be having multiple years
So according to these multiple years, what is the logic when this helper column is created ?​
If this logic can be well explained so it should be automatized within the VBA procedure.​
If not possible, so the helper column must be created manually before executing the VBA procedure …​
As data will be last 3 months, I use 2019M+Month (05) to create helper column manually
instead we use last digit on column B in output file to match and extract value from input file. I have modified the formula on column F in the output file
Ok so for Input2 just needs an helper column for the year/month so a total of 6 columns.​
As I wrote « Considering to allocate output workbook without any formula via a VBA procedure »​
meaning output workbook does not need any formula … Do you agree ?​
Directions to apply before executing the demonstration :​
  • Input2 workbook must be saved with 6 columns with a helper for the year/month in column A.
  • The demonstration expects the input workbooks in the same output workbook folder.
    If it's not the case, just amend the path in the F1 variable in the code …
  • output workbook :
  1. Delete column L then delete column H in order column J is the last used.
  2. Save this workbook as .xlsb binary format or as .xlsm macro format.
  3. Paste this demonstration to the Sheet1 worksheet module :
Sub Demo1()
     Dim F1$, F2$, R&, V, Rw As Range, W
         F1 = ThisWorkbook.Path & Application.PathSeparator & "Input1.xlsx"
         F2 = Replace(F1, "1", "2")
         If Dir(F1) = "" Or Dir(F2) = "" Then Beep: Exit Sub
         Me.UsedRange.Offset(1).Clear
    With GetObject(F1).Worksheets(1).UsedRange.Rows
        .Range("A2:D" & .Count).Copy [B2]
        .Range("E2:E" & .Count).Copy [H2]
        .Parent.Parent.Close False
    With Me.UsedRange.Columns
         R = .Rows.Count
         V = Evaluate(.Item(2).Address & "&"" ""&" & .Item(4).Address)
    With GetObject(F2).Worksheets(1).UsedRange.Rows
        For Each Rw In .Item("2:" & .Count)
                W = Application.Match(Rw.Cells(1).Value2 & " " & Rw.Cells(4).Value2, V, 0)
            If IsError(W) Then
                R = R + 1
                Cells(R, 2).Value2 = Rw.Cells(1).Value2
                Rw.Columns("C:D").Copy Cells(R, 3)
                W = R
                Rw.Cells(5).Copy Cells(W, 6)
                Rw.Cells(6).Copy Cells(W, 9)
    With Me.UsedRange.Rows("2:" & R).Columns
         .Item(1).Value = Date
        .Item(7).Value2 = Evaluate(.Item(5).Address & "-" & .Item(6).Address)
       .Item(10).Value2 = Evaluate(.Item(8).Address & "-" & .Item(9).Address)
