Good afternoon. I would appreciate your assistance with creating an Excel formula.
I want to divide a string, which is separated by spaces, in cells of column A into separate columns B, C, and D.
I also want to extract the surname from the name and middle name (if applicable) in column C.
How can I modify the IF formula in column D to achieve this?
Some strings with full names do not have a middle name, so the surname must always appear in column D.
In this case, cells in column C should remain empty.
I also need to ensure that the formula in column D can extract the surname together with any suffixes,
not limited to 8 surname characters.
How can I create a function that automatically caters to different surname strings? D column?
I have more precise information in the attached Excel file.
Thanks in advance for your valuable help.
