help to adjust macro in advanced filter
RAM72
Recorded advanced filter macro from column H to J of unique values copied to range column AC to AE of same sheet named workings , this same range is then cut to another sheet named summary report in same workbook.
Can anyone one help to adjust vba macro in a more elegant way with some modifcations in red ***( )***to last row of data
Sub testtestunique()
' testtestunique Macro
Range("H1:J629").AdvancedFilter Action:=xlFilterCopy, CopyToRange:=Range( _
"AC1"), Unique:=True **(up to last data in column)**
Columns("AC:AC").EntireColumn.AutoFit
Columns("AD:AD").EntireColumn.AutoFit
Columns("AE:AE").EntireColumn.AutoFit
Range("AC1:AE1").Select
Selection.Cut **(up to last data in column)**
Sheets("Summary Report ").Select
Range("A1").Select
ActiveSheet.Paste ***(Autofit columns**)
Something like
Sub test()
    With Sheets("summary").Cells(1)
        Range("H1:J629").AdvancedFilter 2, , .Cells, 1
        .CurrentRegion.EntireColumn.AutoFit
Something like
Sub test()
Tested it works well ,but I noticed that when I am on summary sheet It did not work properly or sometimes gives me unexpected results.
So I should always be on active sheet workings for the macro to works.
Is it possible to adjust on whatever sheet I am in the workbook, the macro works
Thanks if you couls adjust.
You can count rows via code.
Dim lRow As Integer
'Count last row with data
lRow = Sheets("YourSheetNameHere").Range("H" & Rows.Count).End(xlUp).Row
Sheets("YourSheetNameHere").Range("H1:J" & lRow).AdvancedFilter
Sub test()
    With Sheets("Summary Report ").Cells(1).CurrentRegion
        Sheets("workings").Cells(1).CurrentRegion.AdvancedFilter 2, , .Cells, 1
  • test adbvanced filtercopu_test.xlsm
