Help required for macro
sudipto3003
Dear Friends,
I have attach herewith a "Merge Worksheets Code" example file found from this side. A very useful file this is(for me at least), as i don't know the macro well i am asking your help. what i need:
1> Answer Sheet name should be "Output Total" in place of "RDBMerge Sheet"
2> When "Test 2" running, the output must include the Headers at the first row(the Headers should be same in each sheet in my data will be same) & need the Sheet name at last of the each row which is in "Test 1".
Hope i am clear and looking for your help....please...
  • MergeWorksheetsCode.xls
Hi Sudipta..
Please check the attached..
PS: Didn't check all the code.. just made changes only in the required section..
aasha kori kaaj korbe.. :)
hi debraj,
darun kaaj koreche.....
but where is the "Sheet name" at the last of each row like "Test1"? please give some of your valuable time for this.
hi debraj,
i have done it myself, but not confident... will you please confirm that the code of "Test2" is ok, thanks a lot for help in advance
  • MergeWorksheetsCode_1.xls
