Help required for data validation formula
Bimmy
I came across a workbook which uses below formula in data validation.
=OFFSET(name,MATCH(LEFT(B3,LEN(B3)),LEFT(names,LEN(B3)),0),0,SUMPRODUCT(--(LEFT(names,LEN(B3))=B3)),1)
The data is in sheet2 Column A from Cell 2 to Cell12
Data validation is in Sheet1 Column B.
2 name ranges are being used as below -
Name
Names
Idea is for the user to type the starting character of a word say A and click on the validation arrow which will give them all the possible words starting with A.
Problem -
If I try to add more data in Column A of sheet2, the data validation does not work.
Explanation -
If I add data from Cell 13 onwards in sheet2, data validation does not pick up the data added.
Kindly assist by providing full formula.
Have attached sample sheet for reference.
Note -
I don't have any idea about how the above formula works. I just came across the file while googling.
Worked fine for me.
One issue though. You have data validation list for Column C set to $C$1:$C$1
that needs to be changed (though it won't impact Column B validation).
But since C is dependent on B, just do lookup instead of Data validation there.
Hello Chihiro,
Thank you for responding.
I made few changes -
Deleted Column C from Sheet 1 and Column B from Sheet 2
Changed the names in Column B from Sheet2.
Now data validation does not work as stated from my original post.
Have attached sheet.
Kindly advise what changes needs to be done.
Make sure that the name list in sheet2 is sorted in alphabetical order.
Or the formula/validation won't work.
Perfect...Thanks Chihiro..
