Khalid NGO Excel Ninja Aug 11, 2014 #1 Hello Everyone, Greetings... Once again need your help. I tried to get N/A for the cells having 0 value, using CF: =(A1<1) Further I need, it shows N/A too if cells are Blank (Range = A1:A5). I tried my best to get but Is there any way? Sample file also attached. Thank you, Khalid Attachments Conditional Formatting (NA for Blank Cell).xlsx Conditional Formatting (NA for Blank Cell).xlsx 10.7 KB · Views: 3
Somendra Misra Excel Ninja Aug 11, 2014 #2 Hi Khalid, You requirement is bit confusing; you want cells with 0 values as N/A??? Regards,
Khalid NGO Excel Ninja Aug 11, 2014 #3 Hi Somendra, Yes if cell = 0 (it show N/A) its working by using CF =(A1<1) Custom Format "N/A" I need the same N/A if cell contains no value (blank) I mean my empty cells should show "N/A" in the above range.
Somendra Misra Excel Ninja Aug 11, 2014 #4 @Khalid NGO I doubt that is possible through CF as it is like putting a default value in empty cell, and CF are not meant for that purpose. Regards,
Khalid NGO Excel Ninja Aug 11, 2014 #6 Somendra Misra said: @Khalid NGO I doubt that is possible through CF as it is like putting a default value in empty cell, and CF are not meant for that purpose. Regards, Click to expand... Oh: Thanks Somendra, i will try to manage without N/A in my blank cells. Thanks for explanation.
