I need help regarding Validation drop down menu. I have a file which will track the Funds collected by 20 people month on month.
I am using Offset function to pull the data through the drop down menu but i am not able to do that. Please help me out in this as this is for a Charity purpose and I need your help in this Issue. If the template which i have prepared is not that good pls suggest a proper template which will fulfil my needs in a very presenting way.
I have 7 Columns and 20 rows of data in the table. I have created the same tables for all the months O4 to CT4. I have prepared a template (B4 to H4).
My requirement is when i select the month in B4 i need the data to be pulled from the corresponding tables O4 to CT4.
I used Offset function (Is it an appropriate function here) but that is not helping me out. When I select the Month from the Drop down in B4 i need the Data of Donor Name, Transfered Date, Bank, Reference No, Amount, Status, Notes to be displayed in the main template B5 to H5. Column J to CT will be hidden.
Please help me out in this regard. This is for a charity purpose.
Sample file attached....Link for the file
https://docs.google.com/open?id=0B_8nXiEldUKKM2JHQ2x3cXJMNTQ
