I have one column (AM) which has + and - %'s. I would like to have a running total of the +% and -% values separately. Is there a formula or combination of formulas to do this? I have tried some formulas (incorrectly). TIA .
I have reservations about the idea of summing percentage change. If you apply -50% twice, do you finish with -100% or -75%? For percentages applied successively the formula would be
= (1 + p₁)(1 + p₂) - 1
A 365 solution to the problem would be
