help putting first letter of each word in the same cell upper case
I'm working with a Userform in excel and I found a macro to make the first letter of a word upper case in each cell, with this Userform I'm entering data in each cell.
For Each cell In Application.ActiveSheet.UsedRange
    If (cell.Value <> "") Then
    cell.Value = UCase(Left(cell.Value, 1)) & Right(cell.Value, Len(cell.Value) - 1)
This is what I require:
1 - How do I modify this code in order to make upper case the first letter of each word in each cell in column C and D
2 - In column B I will write a comment in a paragraph form. How can I make the first letter of the first word upper case and also after a dot space Ex:(Hi. How are you?)
Thank you in advance
Instead of using left/right, you can use the PROPER function.
Formula solution:
=PROPER(A2)
Code solution:
Sub ProperWords()
Dim c As Range
For Each c In ActiveSheet.Range("C:D").SpecialCells(xlCellTypeConstants)
    c.Value = WorksheetFunction.Proper(c.Value)
Next c
To do like in your part 2:
Sub ProperSentences()
Dim c As Range
For Each c In ActiveSheet.Range("B:B").SpecialCells(xlCellTypeConstants)
    c.Value = SentenceCase(c.Value)
Next c
'Function obtained from:
'http://www.mrexcel.com/forum/excel-questions/356800-capitalize-only-first-letter-text-string.html#post1764045
Function SentenceCase(txt As String) As String
Dim e
For Each e In Split(txt, ".")
    SentenceCase = SentenceCase & ". " & UCase(Left$(Trim(e), 1)) & _
        LCase(Mid$(Trim(e), 2))
SentenceCase = Mid$(SentenceCase, 3)
End Function
Thank you Luke M for the reply.
I attached a sample doc. I'm not a macro savvy. would you mind inserting the codes in my doc. I inserted the one to make Uppercase the first letter of each word in columns C and D.
1 - Where do I put the code to make column B Uppercase in the first letter of the first word and also after a dot.
2 - because the document will have several columns? where does the code to make first letter of the first word uppercase goes for the rest of the columns
Thank you
Hi Eddy,
Do you want to run the code when a user adds a new record, or everytime the workbook opens (which seems like overkill), or just a one shot?
If just a one shot, copy all of this to a module, change the range definitions where I comment, and then run the RunMe macro.
Sub RunMe()
'this is the macro to run
Dim rngFirst As Range
Dim rngSecond As Range
'Which cells do you want to capitalize every word?
Set rngFirst = Range("C:D")
'Which cells do you onle want to capitalize start of each sentence?
Set rngSecond = Range("B:B")
Call ProperWords(rngFirst)
Call ProperSentences(rngSecond)
Private Sub ProperWords(rngWords As Range)
Dim c As Range
For Each c In rngWords.SpecialCells(xlCellTypeConstants)
Next c
Private Sub ProperSentences(rngSentences As Range)
Dim c As Range
For Each c In rngSentences.SpecialCells(xlCellTypeConstants)
Next c
Dim e
End Function
Just FYI, the Proper worksheetfunction/application method is better at dealing with irregularities (e.g. names like O'Leary) than StrConv is.
