Help on VBA scripting
Raja Kamarthi
Hello Friends,
I have a sheet which has conditional format applied to a set of cells. I applying a VBA script (pls refer below) in this sheet to hightlight the "ACTIVE CELL" but when I am doing so, the current existing conditional format applied for other selected cells gets deleted. Is there a way to fix this?
Cells.FormatConditions.Delete
With Target
.FormatConditions.Add Type:=xlExpression, Formula1:="TRUE"
With .FormatConditions(1)
With .Borders(xlTop)
.LineStyle = xlContinuous
.Weight = xlThin
.ColorIndex = 15
With .Borders(xlBottom)
.Weight = xlThin
.ColorIndex = 15
.FormatConditions(1).Interior.ColorIndex = 20
Raja Kamarthi
Its been quite a while now looking out for someone to resposnd to my query.
Friends, please take out sometime and help me out as this is on high priority.
I just need a VBA script which highlights the active cell and at the same time doesnt delete the active conditional formatts in the sheet.
Thanks in advance
Raja
Hi !   LoL ‼   ->   Just remove the second line ‼   (
This line remove the format conditions for all the sheet's cells ‼
@Raja
Hi
i can't get the point from you actually what do you want
as per my understand try to replace the code with
cells.FormatConditions.Add
Other wise please upload a file
SP
Hi Raja,
I have not tested this extensively but see if this works for you. You can add formatting conditions of your liking.
It does not use conditional formatting.
[pre]
Static oRange As Range
If oRange Is Nothing Then
Set oRange = Target
With Target.Interior
.ColorIndex = 15
With oRange.Interior
.ColorIndex = xlColorIndexNone
Set oRange = Target
.ColorIndex = 15
[/pre]
@ Marc L: Thanks for your comment but unfortunately it was of not much help
@ sgmpatnaik & shrivallabha: Manys Thanks for your inputs. May be I should I have put my query in a precise way for your better understanding. I tried hard to upload the file but all my efforts have gone in vain.
I have 2 VBA codes which I want to run parallely. Below are the codes:
Code 1:
Range("C13").Value = activecell.Value
Code 2:
Code shared by shrivallabha (above)
Can we link both the codes and have them run simultaneously?
Thanks,
Raja
@Raja
Hi
Please add the code before the Vallabha Code
Range("C13").value = activecell.Value
Set oRange = Target
.ColorIndex = 15
Set oRange = Target
.ColorIndex = 15
SP
@ sgmpatnaik: Much Thanks bro but when I tried running the script shared by you, I find only a part of code being applied i e "Range("C13").value = activecell.Value" is working absolutely fine but the active cell is not getting highlighted/formatted.
Please look into this
Thanks,
Raja
@Raja
Hi
You mean you want to color the Cell C 13 also including the Selected Cell
is this correct
SP
@sgmpatnaik: I'm not sure if I got the right way of uploading a file, please click on the link to access the file:
https://www.dropbox.com/s/p105tbpzwiwpsjl/Sample%20Sheet.xlsm?m
Do let me know if you are unsuccessful in doing so.
Thanks,
Raja
@sgmpatnaik: In the spread sheet, when I click on the employee name, the same data gets reflected in cell C13 for eg if I click on cell E11 (Syed Nazim Quadri), this name gets reflected in cell C13 as well. Now I want the cell E11 to get highlighted with some conditional formatting.
Thanks,
Raja
Hi Raja..
Nice work..
*> Please select C7 to H11.
*> Apply Conditional Format as:
Format Only cell that Contain >
Cell Value >
Equal to >
=$C$13
Set Format and Apply..
Deb
@Debraj Roy: Many many Thanks for your input. I spent a good amount of time looking out for a solution and now finally your resolution has brought a much needed relief to me.
A big thanks to all the excel experts who have been helping me out unconditionally.
Raja
@Raja
Hi
sorry for my late replay yesterday my net was disconnected suddenly
Please check this file
https://dl.dropbox.com/u/75654703/Sample%20Sheet.xlsm
Have a nice day
SP
