Help!!! Is it possible to only show what is different between two columns
Tim326515465
Is it possible to show only the difference between two columns and have what is different in another column.
example
column A_______Column B
123___________123-ce.abc
234___________a234.bcd
123___________103-a.cde
Then column C i would want it to say
Column C
-ce.abc
a.bcd
0-a.cde
Welcome to Chandoo. Org forums.
You'd want to implement a formula like in cell C1:
=SUBSTITUTE(B1,A1,"",1)
But there will be couple of items to consider.
1. Will column B always have longer text as compared to column A?
2. Will you have data like
abc, abcabcabc
in column A and column B respectively? What will be expected result if answer is yes.
abc, abcabcabc
1. Yes column B will always be longer.
2. 95% of the time column A will match the beginning of column B. Column A format will have a mixture of letters and numbers and special characters. Column B may have 1 or more characters at the end of column A (column A will have 123 and column B will have 123a) but will always have ".a2" or ".abc". Column B would look like 123a.a2 or 123a.abc or 123.a2 or 123.abc.
80% of the time the format of column A will be 123456, AB123456, 12-345678
