Help in VBA Macro Correction in coding
Hi Team,
I built a data allocation on a VBA Macro file, i need help on 2 criteria.
1. in chemical sheet column named "Hierarchy" begins with "10" data should available but iam getting multiple need to correct.
2. in non chemical sheet column named "Hierarchy" begins with "10" should be deleted.
Pls help on same
enclosed sample file.
Jawahar
Hi, for your #2 according to your attachment a VBA demonstration for starters :​
Sub Demo2()
        Const C = "10*", H = 50
    With Sheet2.UsedRange.Columns
        If Application.CountIf(.Item(H), C) = 0 Then Exit Sub
       .Item(H).AutoFilter 1, C
       .Offset(1).EntireRow.Delete
       .AutoFilter
