Help in VBA code
a_dani20
Hi guys.. i am trying to create a sshort macro for calculation of incometax but it is showing " type mismatch error". Pls help. Also any suggestions to improve this macro are welcome...
Sub IT()
Dim Incometax As single
Dim ExemptionLimit As single
If Range("b6") = "Male" Then
ExemptionLimit = 190000
ElseIf Range("b6") = "Female" Then
ExemptionLimit = 225000
Else: ExemptionLimit = 250000
If Range("b9") <= 300000 Then
Incometax = (Range("b9") - ExemptionLimit) * "10.3%"
ElseIf Range("b9") < "800000" Then
Incometax = Incometax + (Range("b9") - "300000") * "20.6%"
Else: Incometax = Incometax + (Range("b9") - "800000") * "30.9%"
MsgBox (prompt: = _
Range("b5")&" your income tax is " & Incometax)
Hi there a_dani20
I didn't spend long on this and got the mesgbox so should be OK. Just a few changes highlighted by 'X
Sub IT()
Dim Incometax As Single
Dim ExemptionLimit As Long
Dim sAnsw As String 'X see below
Incometax = (Range("b9") - ExemptionLimit) * 0.103 'X if it's in quotes as VBA won't see as a number
Incometax = Incometax + (Range("b9") - "300000") * 0.206 'X
Else: Incometax = Incometax + (Range("b9") - "800000") * 0.309 'X
sAnsw = MsgBox(prompt:=Range("b5") & " your income tax is " & Incometax) 'X I have never really understood why but the msgbox seems to have to be assigned to a string variable - issue has sometimes driven me nuts - maybe someone else knows why
Sorry didn't see the quotes also around other numbers eg "800000" remove all quotes.
Below again without any comments...
Sub IT()
Dim sAnsw As String
ElseIf Range("b9") < 800000 Then
Incometax = Incometax + (Range("b9") - 300000) * 0.206
Else: Incometax = Incometax + (Range("b9") - 800000) * 0.309
Regarding using a variable with MsgBox--
MsgBox is a function, and functions are designed to return information when you call (use) them. The MsgBox function actually returns a number (a LONG, aka long integer).
If you don't specify any buttons for the message box other than the default OK, the return value will always, I think, be 1 or the constant vbOK, which equals 1, so it's true there's not much to be learned in that case...
You shouldn't have to assign the return value to a variable. The rule for calling a function when you want to discard the return value is to do away with the parenthesis, just as you would call a SUB procedure or an object's method, or use a VBA statement:
MsgBox "message"
[code]MsgBox Prompt:="Hi"
[code]MsgBox "Do you think a computer cares what you think?", buttons:=vbYesNo
If you only have one parameter to MsgBox and you don't name the parameter, it will appaear to allow you to use parenthesis:
MsgBox ("Hello, world.")[/code]
That will work. But it's misleading, because the parenthesis are not being interpreted as enclosing the parameter list, but as specifying the order of evaluation for string addition or concatenation (even though you're not doing that).
This will also work:
MsgBox ("Hello, world."), (vbYesNo)[/code]
since they are serving the purpose of order of evaluation only. (in the second parameter it would be for math operations as vbYesNo is a numeric constant).
Asa
Many thanks asa, that explains why this has been a frustrating problem for me and it's those damn brackets!
a_dani20 here is your code reflecting asa's explanation.
I draw your attention to this line which you may have reason to do but I am curious - male of female elseif this?
Just seems like it might not be triggered.
Sub IT()
Else: Incometax = (Range("b9") - 800000) * 0.309
MsgBox Range("b5") & " your income tax is " & Incometax
thanks asa and John@ReddyBay.. but there is one problem guys macro is running but it is not producing desired result. actually the macro is to calulate income tax of a person depending on type - male, female or senior citizen ( that answers John question!!) and income level of person, but the macro is returning same answer for all type of persons. dont know where i am doing wrong. pls help..
@ a_dani20 I am glad you cleared that up on 3 x genders :)
It might be that B6 must a capitalised word eg Male not male?
Have you stepped through the macro using F8 with the locals window open? This will show the logic of your code and the best way to learn VBA (apart from siging up for Chandoo's VBA course!) In the VB Editor (Alt 11) go view locals window. Then place your cursor somewhere in the code and step though using F8. The locals window should show how your variables change one of which is tax and also how the code handles your if statements etc. It's going to be better if you solve this part of the exercise as you know what you want best in the logic of it.
