jawaharprm
Hi All,
i have 2 sheet "Sheet1" and Sheet"User" which has 3 user need to copy the user and paste in sheet1 at "B" Column repletely till last row, Pls help on same
i have tried some code but not working.
>>> use code - tags instead icode - tags <<<
Sub allocation()
Dim lr As Long
Dim lr2 As Long
Sheet1.Activate
Sheet2.Activate
Sheet2.Range("A2:A4").Select
Sheet2.Range(Selection, Selection.End(xlDown)).Select
Selection.Copy
lr = Sheet1.Cells(Rows.Count, "B").End(xlUp).Row + 1
Sheet1.Activate
Sheet3.Range("B" & lr).Activate
Sheet3.Paste
