Dinesh_Excel
Hi Friends,
Need your help for resolving the below with the below condition.
Appreciate your help on the same.Attached sample for your reference.
- Put filters in column “G2” field, and select only fields containing WG1,WG2,WG3,WG4,WG5,WG6 except WG7, WG1_BDF, WG4_MDM and then from a range “AK” it should match any incident in column “A” incidents and then Print it in column AA as “Scope”
- Then put filters in the “H2” field and remove those having BDF, SEAL and MDM ( Master data management), VDM ,Vendor data management, Seeburger and then Print it in column AA as “Scope”
- In K2 field, exclude those containing words like “authorization” and then Print it in column AA as “Scope”.
