help getting VBA not to print "Ranges" in worksheets if "Total" in given table range is = 0
Status
Not open for further replies.
ArbeitWali
Hey Guys/Ladies,
My code currently selects a set number of Named Ranges to print.. It prints everything. Even zero totals..aaargh.
I need help getting VBA code not to print "Ranges" in worksheets where the "Total" any given table is "0 ".
Sub PrintCDivSum()
'error trap added for printing support on 64 and 32 bit OS
Dim ws As Worksheet
Dim ws2 As String
Dim DefPrintName As String
DefPrintName = Application.ActivePrinter
UserForm1.Show
If UserForm1.Cancel = "True" Then
  Unload UserForm1
  Exit Sub
If UserForm1.OK = "True" Then
  If UserForm1.OptionButton2.Value = True Then
  Application.ActivePrinter = "Adobe PDF on Ne02:"
  Else: End If
Unload UserForm1
ws2 = ActiveSheet.Name
  With ThisWorkbook
  For Each ws In .Worksheets
  Select Case ws.Name
  Case "GC's"
  With ws
  .PageSetup.PrintArea = "" 'clear any existing print area
   .PageSetup.Orientation = xlPortrait
  .PageSetup.PaperSize = xlPaperLetter
  .PageSetup.Zoom = False
  .PageSetup.FitToPagesWide = 1
  .PageSetup.FitToPagesTall = 1
   .PageSetup.PrintArea = .Range("l1a,l2a").Address
  Case "DIV 2"
  With ws
  .PageSetup.PrintArea = .Range("l3a,l4a,l5a,l6a,l7a,l8a,l9a,l10a,l11a,l12a,l13a").Address
  Case "DIV 3"
  With ws
  .PageSetup.PrintArea = .Range("l14a,l15a,l16a,l17a,l18a").Address
  Case "DIV 4"
  With ws
   .PageSetup.PrintArea = .Range("l19A").Address
  Case "DIV 5"
  With ws
  .PageSetup.PrintArea = .Range("l20a,l21a").Address
  Case "DIV 6"
  With ws
  .PageSetup.PrintArea = .Range("l22a,l23a").Address
  Case "DIV 7"
  With ws
  .PageSetup.PrintArea = .Range("l24a,l25a,l26a,l27a,l28a").Address
  Case "DIV 8"
  With ws
  .PageSetup.PrintArea = .Range("l29a,l30a").Address
  Case "DIV 9"
  With ws
  .PageSetup.PrintArea = .Range("l31a,l32a,l33a,l34a,l35a,l36a").Address
  Case "DIV 10"
  With ws
  .PageSetup.PrintArea = .Range("l37a,l38a").Address
  Case "DIV 14"
  With ws
  .PageSetup.PrintArea = .Range("l39A").Address
  Case "DIV 15"
  With ws
  .PageSetup.PrintArea = .Range("l40A,l41a,l42a").Address
  Case "DIV 16"
  With ws
  .PageSetup.PrintArea = .Range("l43A").Address
  'Case Else
  End Select
  Next ws
Sheets(Array("GC's", "DIV 2", "DIV 3", "DIV 4", "DIV 5", "DIV 6", "DIV 7", "DIV 8", "DIV 9", "DIV 10", "DIV 14", "DIV 15", "DIV 16")).Select
ActiveWindow.SelectedSheets.PrintOut Copies:=1, Collate:=True, IgnorePrintAreas:=False
'ActiveWindow.SelectedSheets.PrintPreview
Application.ActivePrinter = DefPrintName
Sheets(ws2).Select
Status
