Help for small formula. INDEX and MATCH
bhasoriya
Hello Friends,
Need your help for a small formula in Index and match.
In sheet 1
B C
1-Mar-12 Jani
1-Mar-12 Jani
1-Mar-12 Mehta
1-Mar-12 Mehta
1-Mar-12 Patel
1-Mar-12 Thakkar
In sheet 2
A2 has date (1-Mar-12)
B2 has =INDEX(Sheet1!C:C, MATCH($A$2,Sheet1!B:B,0)) (Result is Jani)
If i copy this formula in B3 then result would be exclude duplicate names and should appear next new name.
Result would be in
B3 Mehta
B4 Patel
B5 Thakkar
Thanks a lot
Hi Bhasoriya ,
It's not so simple !
Go through the following links :
1. http://www.get-digital-help.com/2009/03/30/how-to-extract-a-unique-list-and-the-duplicates-in-excel-from-one-column/
2. http://www.get-digital-help.com/2009/04/16/create-unique-list-from-column-where-an-adjacent-column-meets-criteria/
Hi Bhasoriya ,
Assuming your data is from A1 to B6 (at sheet1)
At sheet2 you have date(1-Mar-12) at A2:
At B2, try this:
=IFERROR(INDEX(Sheet1!B:B,MATCH(0,COUNTIF($A$1:$A1,Sheet1!B:B)+IF(Sheet1!$A:$A<>Sheet2!$A$2, 1, 0),0)),"")....CTRL+SHIFT+ENTER (to enter it as an array formula) and copy it down as needed.
For detail explanation, please refer the below link to understand how the formula works..
Reference: http://www.get-digital-help.com/2009/06/27/how-to-create-a-unique-distinct-list-where-other-columns-meet-two-criteria/
Post back in case you require any clarification.
Kaushik
Hello kaushik03,
In sheet2, B2 is showing Result as "Jani" but in
B3,B4 & B5 are still showing "jani"
Is there another way to exclude duplicate names from sheet1 column B in result.
Result should be in
B3 Mehta
B4 Patel
B5 Thakkar
Thanks for helping :)
Hello Bhasoriya
I Think This formula will help you, otherwise please upload a file for better understanding
formula is
=IF(COUNTIF(Sheet1!B:B,$A$2)<ROWS($B$2:B2),"",INDEX(Sheet1!C:C,SMALL(IF(Sheet1!$B$1:$B$10=$A$2,ROW(Sheet1!$B$1:$B$10)),ROW(A1))))
after insert the formula when you are going to press enter use the array method (ctrl+shift+enter) and drag down
With Regards
SP
Hello sgmpatnaik,
I Have upload here file for example.
https://rapidshare.com/files/4060717424/Resouce used.xlsx
Thanks a lot... again
Hi Bhasoriya ,
Check out the file here :
http://speedy.sh/Db8Uy/Resource-used.xlsx
Please note that the formulae are borrowed from the links I had posted earlier , 2 days back.
Also , the formulae will not work if the date is entered in only one row on the second sheet ; for the formulae to work , the date has to be repeated.
Hello Narayank991,
Yes i can repeat the DATE in Sheet 2 from A2 to A26..., as you mention here. But If i am entering same formula in B6 to B25.... It is repeating the name.. It should not be repeated. If name appear once. then He would not be repeated again for that date.
Thanks Narayank991, I had tried the formulas from
But here there are bulk of formulas.. i was confused..
Hi Bhasoriya ,
Have you checked the file I uploaded ? There is no repetition there.
EDIT : Sorry , I'll get back to you on this.
