Help for Match Formula.
Please try the below forumla.
=IF(COUNTIF($C$5:$C$19,H5),"Not Matching","Match")
Thanks,
Suresh Kumar S
Hi Bhasoriya,
Little confusion.. :)
Are you sure you want to assume both are same, as Sizes are same..
B152077 --> c5
B152074
--> h5
Deb
Hello Suresh Kumar,
Yes, this is working. but only for column C & H,
Column F & I skipped..
Please read comment in cell L12.
Thanks for help..:)
Hello Debraj,
I have just seen your comment,
If C5 match with H5 & F5 match with I5 then J5 has to result as "Match"
If something not matching in C5 with H5 & F5 wtih I5 then result would be "Not Match"
Thanks for reply.
