Hi Excel ninjas
i hope you all are fine
I am using this macro which is create by one of member it`s working fine but I need some changes in this macro
I have some data in excel . I need in main sheet data convert to different sheet VERIFICATION format with details , details picked from main sheet . but with some condition
like
as45455656-Bn3
as45455656-Bn4
as45455656-Cn3
as45455656-Cn4
dfd343567-B
dfd343567-C
above number are same before - it`s mean number is same for the same number I need one sheet, in template filed given like below
if after number -BN4 so amt is 2340, b stand for black and c stands for color
if there is only number without -Bn4,Bn3,Cn3,Cn4 it`s mean black N4 in template
and 3rd condition if after number-b or number-c it`s stand black n4 and color N4.
Anu
VBA Code:
like
as45455656-Bn3
as45455656-Bn4
as45455656-Cn3
as45455656-Cn4
dfd343567-B
dfd343567-C
Anu
VBA Code:
Sub SheetMaker()
Dim ShtName As String 'Sheet NameDim MySht As String 'True/FalseDim ws As Worksheet
Dim MyNum As String 'NumberDim MyCust As String 'CustomerDim MyAddr As String 'AddressDim MyCity As String 'CityDim MyMod As String 'Model No.Dim MyAmt As String 'AmtDim MyDT As String 'DateDim MyPN As String 'Partner NameDim MyPA As String 'Partner AddressDim MyPC As String 'Partner City
Worksheets("main sheet").Select
Range("A2").Select
Do Until IsEmpty(ActiveCell)
ShtName = ActiveCell.Value
For Each ws In ActiveWorkbook.Worksheets
If ws.Name = ShtName Then
MySht = True
Exit For
MySht = False
If MySht = False Then
MyNum = ActiveCell.Value
MyCust = ActiveCell.Offset(0, 1).Value
MyAddr = ActiveCell.Offset(0, 2).Value
MyCity = ActiveCell.Offset(0, 3).Value
MyMod = ActiveCell.Offset(0, 4).Value
MyAmt = ActiveCell.Offset(0, 5).Value
MyDT = ActiveCell.Offset(0, 6).Value
MyPN = ActiveCell.Offset(0, 7).Value
MyPA = ActiveCell.Offset(0, 8).Value
MyPC = ActiveCell.Offset(0, 9).Value
Worksheets("Template").Copy Before:=Worksheets("Template")
ActiveSheet.Name = MyNum
Range("C3").Value = MyCust
Range("C4").Value = MyAddr
Range("C6").Value = MyCity
Range("C8").Value = MyMod
Range("F8").Value = MyNum
Range("H3").Value = MyPN
Range("H4").Value = MyPA
Range("H6").Value = MyPC
Range("D11").Value = MyAmt
Range("F11").Value = MyDT
Range("A1").Select
Loop
