help for a vba code to copy Some sheets to another workbook
Maxwolf
well there is my case :
i would like to be able to copy all sheets EXCept this sheet name : Template, to another workbook. The user should be able to name the workbook where he want to copy the sheets and the directory where he want to copy the file.
thank you for your help
Try this:
Sub CopySheets()
Dim sWB As Workbook, dWB As Workbook
Dim FldrPicker As FileDialog
Dim wSht As Worksheet
Dim shtCount As Long
Dim fName As String
With Application
    .ScreenUpdating = False
    .DisplayAlerts = False
Set sWB = ThisWorkbook
fName = Application.GetOpenFilename _
        (FileFilter:="Excel Files (*.xls*),*.xls*", _
        Title:="Select file to which you want to copy sheets...", _
        MultiSelect:=False)
If Len(fName) > 0 Then
    MsgBox "No file selected.", vbExclamation, "Sorry!"
    GoTo CleanExit
    Set dWB = Workbooks.Open(fName)
    For Each wSht In sWB.Worksheets
        If wSht.Name <> "Template" Then
            wSht.Copy After:=dWB.Sheets(dWB.Sheets.Count)
            shtCount = shtCount + 1
    Next wSht
    If shtCount > 0 Then
        MsgBox shtCount & " Sheet(s) have been copied to " & dWB.Name, vbExclamation, "Sheets Copied..."
        dWB.Close SaveChanges:=True
        MsgBox "There were no sheets to copy.", vbExclamation, "No sheets to copy..."
        dWB.Close SaveChanges:=False
CleanExit:
With Application
    .ScreenUpdating = True
    .DisplayAlerts = True
thank you, it work if i change, first this code If Len(fName) > 0 Then must be replace by
If Len(fName) < 0 Then
this is asking me to open another workbook and then copy the sheets. but i do not have another workbook, the other worbook does not exist .
i want the code to ask the user to put a name for a new workbook and then only after that the sheets should be copied to the new workbook create by the user.
This should do the work:
Sub CopySheets()
Dim fName As String
With Application
        If dWB Is Nothing Then
            wSht.Copy
            Set dWB = ActiveWorkbook
Next wSht
If Not dWB Is Nothing Then
    fName = Application.GetSaveAsFilename _
        (InitialFileName:="", _
        FileFilter:="Excel Files (*.xlsx), *.xlsx", _
        Title:="Save New file As...")
        If fName = "False" Then
            MsgBox "File not Saved, Action Cancelled."
            GoTo CleanExit
            dWB.SaveAs Filename:=fName, FileFormat:=51
            MsgBox shtCount & " Sheet(s) have been copied to " & vbNewLine & _
            fName, vbExclamation, "Sheets Copied..."
CleanExit:
With Application
