Hi all,
Need help with coming up with either a Macro or a formula which would count the skips between the picks of a certain number. For example, on the "Ball1 Stats" sheet, Starting with # 1 in B6, it has been picked 23 times (B7). I would like to know how many skips are between each of the 23 times #1 was picked in the "Master" sheet. On the "Master" sheet, in B column (Ball1) the list starts with date of 5/4/2015. Start counting down from B2. I am wanting to count skips between picks of the number 1.. So the first time the number 1 is picked for ball 1 is on 6/18/2015 (B15). From B2 to B14 is 13 skips, B15 is the #1. Then to represent the #1 put a Zero. Start counting again at B16. The next time #1 is picked is B18, 6/29/18 . B16 to B17 is 2 skips, then put a 0. Do this all the way down to Say B500 to cover future picks. I would like to do this for each of the numbers, 1 to 60 for ball 1, ball 2, ball 3, ball 4 and ball 5.
Thank you in advance, and as always your help is greatly appreciated.
Dave
Dave
