Having a brain fail - trying to identify and format specific values with VBA
PipBoy808
I'm not having my brightest morning and can't seem to get around a simple problem I have.
I have a range of data in column B that I want Excel to cycle through. There are three specific values it needs to identify, and subsequently format those entire rows differently.
I've written this:
Dim j as long
For j = 12 To lastRow 'lastrow has been previously defined and is correct
If Cells(j, 2).Value = "Header 1" Or "Header 2" Or "Header 3" Then 'I keep getting an error here
Cells(j, "B").RowHeight = 25
Cells(j, "B").WrapText = False
Cells(j, "B").Font.Bold = True
Rows(j, "B").Font.Color = vbWhite
Rows(j, "B").Color = vbBlack 'black out the entire row to signify a header
Next j
I know the answer is staring me in the face, but can anyone help me out?
Pipboy
Your code is erroneous because you start by saying;
then you don't qualify the second part by saying Or Cells(j,2) = "Header 2"
The part in bold is what you are leaving out.
You need to do it like this.
If Cells(1, 2) = "Header 1" Or Cells(1, 2) = "Header 2" Or Cells(1, 2) = "Header 3" Then
Take care
Smallman
You can try like this also..
If Evaluate("=OR(" & Cells(j, 2).Address & "={""Header 1"",""Header 2"",""Header 3""})") Then
One more approach using Select
Select Case Cells(j, 2).Value
  Case "Header 1", "Header 2", "Header 3"
  'Your code here
End Select
