Gantt chart - need help understanding how the formula works
J Singh
Hi
Could you please explain how the following formula works - what does "fillblock" in the formula means? Tried to make sense of how the formula works but couldn't…
=IF(AND(COLUMNS($F$5:H6)>=$C6,COLUMNS($F$5:H6)<=$D6),IF(COLUMNS($F$5:H6)-$C6<ROUND(($D6-$C6+1)*$E6,0),fillblock,""),"")
thanks
  • Gantt Chart Template - by week with completions.xlsx
Hi Singh,
The formula has two IF condition checking as below:
The red portion is checking if the cell is between the start and end week mention in column C and column D.
If above is YES then it will check the blue portion that is checking how much percentage of job is completed. So say a task is for five week. CF will put five cell with blue colour. And each cell is 20% of the task so if %age completion is 40% so the blue part will put the special character in the cell this is the special character
defined through fillblock in name manager.
Access the name manager through formula tab or keyboard shortcut Ctrl+F3, you can see there.
If any of the above condition is not TRUE than the formula will put a null string "" in the cell.
Hope this will clear the formula.
Hi Singh,
Thanks Somendra Mishra - thanks for explaining how the IF statements and conditional formatting works - Sorry I should have been more clear in my ask, i want to know how excel knows to only fill partial cell and not the full cell if % task completed is anything but 100%
Hi Singh ,
You should be able to figure this out yourself ; just take a closer look at the following :
1. The formula does nothing but fill the relevant cells with the character represented by the named range fillblock. This is a vertical block.
2. There is a range format which does something ; select the cells and look at every aspect of their format.
3. The conditional formatting , in this case , is very simple ; it does nothing but ....
To understand what is happening , first clear the range of its conditional formatting rules , and see what is displayed.
Hi Singh,
Sorry for not understanding your query, but I don't think the filling of block is appropriate, Let us say:
You have a task of one week Activity of row 11, if you put 50% than the block will be there giving a wrong visual information that the task is completed.
Consider another scenario: let us consider the same activity is for two week, so first block will come after 30% and second one will come at 80% so a difference of 50%. I don't think that's the correct information.
Compare it with the CF of Data Bar.
