vaibhav tandon
Hi All,
I am new to this board and this is my first post
The problem goes like this:
In my first sheet I have data in which Component Name(which is actually a project phase) has multiple defects and it has status which is either closed or open.
Component Name Defect Description Status
LNZAR98D "STEP020 - the COND=(4,LT) should be removed Closed
"STEP020 - The new file CURRSUSP" Closed
Remove BLKSIZE Closed
LNZKF30D STEP01, STEP02 etc to be renamed to STEP010 Open
In my second sheet I wsnt to have
Component Name Status
LNZAR98D Closed
LNZKF30D Open
So my problem/issue is that in the second sheet I want "Status" column to be populated automatically based on the values in First sheet.Which means if the last defect of a component name has status "closed" in first sheet then in second sheet the status column should have status as "closed" and if the last defect of a component name has status "open" or "its a blank" in first sheet then in second sheet the status column should have status as "open".
So is there any in excel formula that can be used to get this data in second sheet?If not is this possible through Macro?
I hope that I have explained the problem and would be easy to comprehend.Thanks in advance.
Vaibhav
LNZAR98D Closed
LNZKF30D Open
Vaibhav
