formula help
vikash
In excel i am trying to find a certain value in a row and on that basis want to change the color of a different row in same sheet.
For eg: whenever Tuesday appear in row 1 color of row 9 should change. What formula to use kindly help.
thanks in advance.
Hi Vikash,
How your data looks like?
Can you post a sample with manually filled expected output?
I have posted the sample file what formula to use to get expected result.
  • sample file.xlsx
So you need row 5 highlighted if row 3 contains Monday
Use conditional formatting as advised above.
Select your range: C5:R5
Go to Conditional Formatting
Formula
=C$3="Monday"
Set the format
Formula
=C$3="Monday"
Set the format
its not happening its changing the color for whole selected range
You may have used:
=$C3="Monday"
instead of:
=C$3="Monday"
See the attached example.
There are 2 highlighted rows
Yellow = dependent on word "Monday" in row # 3
Red = Every 8th column
Check both CF
  • sample file CF Monday.xlsx
