Hey,
Trying to build in a personnel model that assumes salary raises every june of every year. The model is built month by month.
I have an if statement comparing the current month with the start month to determine if the salary should be entered that month. When I try to factor in the raises however, my raise isn't being calculated into the later cells. It doesn't build on the salary-- it only increases the compensation by the raise percentage that month.
so if:
employee 1 started in January 2013 and the current month is Feb 2013, the $100,000 salary is divided by 12. If after 3 months, employee 1 is given a raise in June 2013 of 8%, my formula is 'if(feb 2013 > $jan 2013, (100000/12)*row of raise percentages).
so for feb 2013 to may 2013, the cell is 100000, but in june, it should show 108,000. If I continue dragging the formula, july will show 100,000 again. Help?
How can I build in the raise if I drag that formula across to the next cell?
so if:
