Formula help - letters to numbers & vice versa
Hi All,
I have to convert the product codes from letters to numbers and vice versa.
Existing code: 123F8
Conversion should be: ABC6H
Can you please help. I have attached a sample file. I have researched into "TextJoin" & "INDIRECT" but can't understand it fully.
Thanks!
  • Copy of Book2.xlsx
ferocious12
... without those 'Original' & 'Converted'-values.
Excellent ! many thanks
One variation if you can help. I have codes with varying length some 5 digits some upto 10. I can extend this formula to 10 digits but is there an error handling thing I can include so it pick up the number of digits in the code and adjust the formula accordingly?
63085
If you have Office 365, try to use the TEXTJOIN function.
In C3, array formula (Ctrl+Shift+Enter) copied down :
=TEXTJOIN("",TRUE,IF(ISNUMBER(-MID(A3,ROW(INDIRECT("1:"&LEN(A3))),1)),IF(-MID(A3,ROW(INDIRECT("1:"&LEN(A3))),1)=0,0,CHAR(64+MID(A3,ROW(INDIRECT("1:"&LEN(A3))),1))),CODE(MID(A3,ROW(INDIRECT("1:"&LEN(A3))),1))-64))
Bosco
ferocious12
Which part is challenge for You?
This could explain eg like below with own grammar:
get 'original number' as A reset AB (which would be 'result') Check characters one-by-one if 'letter' then change to number as BB else change to letter as BB endif if 'letter' was zero then BB as 0 add BB in the end of AB Give 'result' as AB
