chirayu
Hi Guys,
The below "for loop" isn't working as I want it to, possibly because my code is incorrect. Unsure. Basically I want it to go through every sheet in the ActiveWorkbook that start with a month name & add a concatenate column (for later vlookup use), otherwise go to next sheet.
What its doing instead is running through the first time, then just keeps adding concatenate columns in the same sheet for the number of sheets there are in the file, instead of doing it on each sheet.
Dim ws as Worksheet
For Each ws In ActiveWorkbook.Worksheets
If ws.Name Like "JAN*" _
Or ws.Name Like "FEB*" _
Or ws.Name Like "MAR*" _
Or ws.Name Like "APR*" _
Or ws.Name Like "MAY*" _
Or ws.Name Like "JUN*" _
Or ws.Name Like "JUL*" _
Or ws.Name Like "AUG*" _
Or ws.Name Like "SEP*" _
Or ws.Name Like "OCT*" _
Or ws.Name Like "NOV*" _
Or ws.Name Like "DEC*" _
Then
Columns("A:A").Select
Selection.Insert Shift:=xlToRight
Range("A5").Select
ActiveCell.Value = "CONC"
If IsEmpty(ActiveCell.Offset(0, 1)) Then
ActiveCell.Formula = "=B6&J6"
Selection.Copy
Selection.PasteSpecial xlPasteValues
Range("B50000").Select
Selection.End(xlUp).Select
Range("A6:A" & ActiveCell.Row).Select
Selection.FillDown
Selection.Copy
Next ws
