Flag 4 digit identical values, regardless of their order, from a set 4 digit numbers from 0000 to 9999
Status
Not open for further replies.
Jeylon
Hello, hope all is well with you. I must say I am truly impressed with you work and your website.
I am having some problems here and I really do hope you can help me out, please and thanks.
I used a formula in excel to generate a set of 4 digit numbers from 0000 to 9999. This worked perfectly!
However, I am trying to flag all 4 digit numbers that contain exactly the same digits, regardless of their arrangement. For example 1, from my list there is a number 1234. I need you to keep the 1234 but flag 1243, 1324, 1342, 1423, 1432, 2134, 2143, 3124, 3214, 4123, 4213, 4312, 4321 (and all other combinations of it) . Example 2, from my list there is a number 0035, I need you to keep the 0035 but flag 0053, 0350, 0530,3500, 5300, 3050, 5030, 3005, 5003 (and all other combinations of it)
I really hope you can provide some support here.
Anticipatory thanks.
Jeylon
Do Your list start from cell H10?
Is Your list vertical or horizontal?
How do You would like to flag those Your named combinations?
Hint: An Excel-sample file,
... with a sample data and expected results
which You could send here,
would help You (and others) a lot.
Jeylon
Jeylon
Ok. Well all the unique 4 digit numbers can be listed vertically and all their flagged combinations can be listed horizontally, thanks.
  • 4 digit numbers generated.xlsx
Jeylon
No, it did not start from H10. All I did was generate all the 4 digit numbers, vertically. Now all I need if for ALL same digit combinations to be pulled out from the list so only unique values would remain. Thank you.
Where is the list of the four digit number you wish to search for?
I sent an excel spreadsheet already. So from the sheet I sent I would like all same 4 digit numbers to be flagged. I really don't know how to do it. Thank you for your help still sir.
Here is the list.
Jeylon
Your file do not have any 4 digit numbers
There are 10000 texts, which looks like numbers.
You skipped:
as well as expected results.
Jeylon
You skipped:
Remember I said I generated a list (10000) of 4 digit numbers? I just want to flag all numbers that have SAME digits, meaning all duplicates, that's all. I will send over the containing ALL the 4 digit numbers. Please highlight, remove or place the duplicates in another cell, thank you.
Jeylon
Based Your original thread (#1)
eg 0001 is same as 0001 0010 0100 1000
that means ... You could have 'left' those 4-digits like 0000 1111 ... 9999
... press [ Do It ] to move Your 'duplicate's to right side.
There are some hints to use too.
Your the latest (#8) reply seems to have 'a bit' different logic,
I'll skip that version.
  • 4 digit numbers generated.xlsb
Jeylon
Sorry if I was not clear in explaining. The attachment looks good, but not exactly as I wanted. Let me send an example for the last time. Sorry to give you so much worries.
Attached are two documents: 1 is what I really want, the other is what you already did before for someone but with THREE digits. I want the same but with FOUR digits. That's it.
I cannot make it clearer.
Thank you still for your help.
  • What I really want..xlsx
  • Example of what you did before..docx
  • Example of what you did before. CORRECTION.docx
Jeylon
About Your 1 is what I really want,
Your writings try to explain I should not see 0010, 0100, ...
... You should give an idea - what do You really want?
... and Your newer layout of that data is different than Your original
You should able to keep something stable ... please.
About You
I did it with FOUR digits ... as You wrote above ... Isn't it Yours That's it?
You seems to send some Word-files too ... no Words for me.
Jeylon
About You
Again, my apologies for not being able to explain it clearly. Thank you for your time.
Jeylon
Seems ...
Anyway, I did one more sample which has some options
- test Yourself, if any of those would give that You had in Your mind.
Jeylon
Seems ...
OMG!!! This is exactly what I wanted! You are a genius. Thank you soooooo much. Wow, I am immensely impressed!!!!!
The attached uses dynamic array functions such as FILTER and SORT to order the digits within each string and remove duplicates.
Sadly, it is not possible to use a single array formula without recursive Lambda functions, so I used an Excel Table to hold the initial list.
  • uniqueDigits.xlsx
Question, lets say I have every number from 0000 - 9999. I want to eliminate the repeats such as 0001 is the same as 0010 or 0100 or 1000. Do I have to eliminate those manually or is there a way to have it done automatically ? thanks for the help. I'm trying to learn Excel and you all get pretty deep into it, tough for me to follow. thanks again.
I know those are all different numbers but as far a the number itself it would be considered the same for what I'm doing.
2374 Is the same as 3247, 7423, 3724 etc.. for those combinations I just want the 2347 (smallest to largest) and eliminate the rest from the list. hope I explained it okay.
Please don't hijack the other person's post.
Open a new post with your new question together with the necessary attachment.
This post closed
Status
