Find Distance between two places by passing Latitude and Longitude
If you want to find the distance and time taken between tow places by passing the Latitude and Longitude of Origin and Destination Via VBA Excel and Google Map.
Here is the UDF
Public Function get_dis_and_time(lat_1 As String, lon_1 As String, lat_2 As String, lon_2 As String)
' Read more about Google API’s here
'https://developers.google.com/maps/documentation/distancematrix/
' we will be using Google API Distance Matrix to get Time and distance between two cities.
Dim surl As String
Dim oXH As Object
Dim bodytxt As String
Dim tim_e As String
Dim distanc_e As String
surl = "http://maps.googleapis.com/maps/api/distancematrix/xml?origins=" & lat_1 & "," & lon_1 & _
    "&destinations=" & lat_2 & "," & lon_2 & "&sensor=false"
Set oXH = CreateObject("msxml2.xmlhttp")
With oXH
    .Open "get", surl, False
    .send
    bodytxt = .responseText
bodytxt = Right(bodytxt, Len(bodytxt) - InStr(1, bodytxt, "<text>") - 5)
tim_e = Left(bodytxt, InStr(1, bodytxt, "</text>") - 1)
distanc_e = Left(bodytxt, InStr(1, bodytxt, "</text>") - 1)
get_dis_and_time = tim_e & " | " & distanc_e
Set oXH = Nothing
End Function
In cell A3 = Origin Latitude
In cell B3 = Origin Longitude
In cell C3 = Destination Latitude
In cell D3 = Origin Longitude
In cell E3 Type =get_dis_and_time(A3,B3,C3,D3)
Download Working File Here https://www.box.com/s/x2ofy9r8cc7bro0p83xq
When I use Google Maps and enter the information, it returns different values than what the code above does. Sometimes by several miles.
It's travel distance over road (or other mode of transportation). So each time you query in browser, it can be different, depending traffic condition etc.
When you query using above code, many of optional values are not set and info isn't real time.
If you want to calculate approximate distance over surface in straight line (i.e. great-circle distances) using lat & long, then use Haversine formula to calculate the distance.
https://chandoo.org/forum/threads/power-map.31577/#post-187726
found this in my files as cleaning out my old laptop we used to use this previously and it was great looks like Google have changed some map items and the map is now not good but it was a great way to do lots of post codes so if anyone has a work around would be good to know
  • Map Builder Sept 18.xlsm
