Filter Data using Advanced Filter and VBA
gazitaliano
Hi I'm having a problem filtering data.
I downloaded the 'Extract data using advanced filter with vba' file and have amended the vba code to suit my own workbook, however when I click on my get data button it only copies over the headers from my table, not the data?
This is the code I have:
Sub getdata1()
Sheets("Sheet2").Select
Range("S8").Select
Range(Selection, Selection.End(xlToRight)).Select
Selection.Clear
Sheets("Sheet1").Range("Table1[#All]").AdvancedFilter Action:=xlFilterCopy, CriteriaRange:= _
Sheets("Sheet1").Range("W1:X2"), CopyToRange:=Sheets("Sheet2").Range("S8"), Unique:=True
Columns.AutoFit
Range("S8").Select
Any help would be great. Thanks
Right I've tried changing my Criteria to W1:W2 and that worked, Y1:Y2 worked, but for some reason X1:X2 isn't producing any results.
Might want to review how the Advanced Filter criteria works, and how the And/Or type logic is calculated.
http://chandoo.org/wp/2011/10/10/how-to-use-advanced-filters/
The code you posted above is looking at all 3 cells, so it's only going to return results here the criteria in W2 and X2 are met at the same time. Y2 is not counted at all.
