Is there a way to filter a list, in place, based on the following logic:
Column A begins with "C" and length >6
I know I can create a helper column with a formula to evaluate the above but I was wondering if you can do this with the Advanced Filter or some other tool (I can't seem to grasp Advanced Filter for some reason)
Thanks,
Jason
Thanks,
Jason
